97` 850 R manual swap, long crank intermittent spark/start Topic is solved
gswede
Year and Model: 850 R 1997
Post by gswede »
So the last vid indicates spark, hooked up coil lead and sure enough, now it fires up..?!!
What could possibly lead it to need 2 minutes of cranking before spark comes along?
Has thanked: 1611 times
Been thanked: 4075 times
Let's try that spark check with a plug attached and grounded with a wire and see if it's still erratic
gswede
Post by gswede »
FIXED!!!
Drumroll....
It was the crank sensor polarity.
Auto flexplate with square trigger holes as the newer flywheels. Install an old flywheel with round trigger holes and you`ll want to reverse sensor polarity.
However, it will fire with wrong polarity, crank time is looonger and your timing will be off.
M4.3
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
gswede wrote: - Short "fan" belt as the AC had been inoperable since 2002, many receipts from PO attempting fixing it. Figured no need for a belt spinning non working equipment.
Do you know what brand/ part number the short belt is? This would be useful to know, several people were looking for a short belt to bypass the a/c compressor.
gswede
Post by gswede »
Nicely done!!
oragex
Post by oragex »
Thanks!
gswede
Post by gswede »
De nada :-)
If you do this, crimp and solder the wires for trouble free DD
And for the love of GOD, keep the auto ECU, the revhang in the manual ECU sux.
Cannot even begin to describe how much better auto ECU driveability is on a manual swapped car than one high mileage 850 original manual with rev hang.
Total control of torque and revs with pedal beats ECU interference, especially during gear change..
henrysin44
Year and Model: 1994 Volvo 855 Turbo
Has thanked: 2 times
Been thanked: 3 times
Post by henrysin44 »
gswede wrote: 23 Mar 2016, 16:54 FIXED!!!
Drumroll....
M4.3
I manual swapped my 850 2 years ago and ever sense my volvo would crank for soooo long, sometimes a scary long time (not very fun to experience on road trips). This post is a life saver, i had no idea about the different flywheels, now it fires up within a second!
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
I'm in the middle of my manual swap on the '97 T5 and wonder if this is going to be an issue.
My car is no longer an M4.3 (Swapped M4.4 a while back) and it's going COP in the process.
I know the M4.4 started quicker, due to the system remembering where is was and not having to find #1 first (like the M4.3), which resulted in shorter start times.
I suppose it won't hurt to swap polarity, regardless.
