96 R ABS module - again
jking4020
Year and Model: 1997 850, 2001 v70xc
Been thanked: 3 times
Re: 96 R ABS module - again
Post by jking4020 »
BEJinFbk wrote:
jking4020 wrote:I also have abs issues. Checked circuit board and was fine. I still installed a replacement abs unit but no change. Speedo will go out any time. Front brakes hum on long stops. And I have to hit my horn to get shifter to move and most electronics to work. Back brakes barley seem to work if at all. It's a 97 850 turbo.
Sounds suspiciously like a bad ignition switch.
The contacts wear out and all kinds of things happens.
It's a really simple swap, though. Budget about 50 bucks
and stick with OEM for the new electrical contact block.
I jiggled key while driving tonight and speedo started working. Very interesting.
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
abscate wrote:
Clemens wrote:So last night i took the left rear brake apart. The parking brake assembly looks good (i adjuated them a whe ago, but better safe than sorry) but the inner piston was stuck so i got it moving again. Since i didn't take the caliper off the car i couldn't really rebuild it, i just broke it loose by locking the outer piston and then pumped the pedal a few times. Might be a temporary fix only. Now the left side seems to work alright again, but i will also di the right reat one as the rubbing still can be felt. Interesting input about the rubber line collapsing. I just had the front ones replaced but will do the rear ones soon as well.
Yeah, that's going to lock up on you again. It might help to flush your brake fluid out and put in fresh, which you should do every two years anyhow, but the corrosion damage is probably already done.
The rear calipers on my 1999 are non-floating type ( caliper stays still, two Pistons move) which last longer but have to be replaced when they freeze. I found the FCP Cardone after markets to be rebuilt OEM ATE calipers at 1/4 the price.
Of course, Abscate was right, it froze up again and I decided to get a rebuilt one (108Euro for an AC Delco one, the only one I could get quickly) since noone here could order me a rebuild kit. I´ll also replace the slider pins. I´ll report back on that in a few weeks. If this Fails again I might have to try a new (used) hydraulic block, but I doubt this is the culprit (i might be wrong, though).
Neverending sagas are so much fun ...
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 1505 times
Been thanked: 3818 times
Ive had luck honing wheel cylinders on old VW drum brakes, but the minute I see sticking in calipers, the decades have taught me to pitch both calipers and replace all the brakes - good for 5 years.
108 EURO? I should start a US-AUS car parts import business on my trips to Vorarlberg..
Clemens
Post by Clemens »
yeah, prices over here for car related things are sometimes ridiculous. years ago when I was on the west coast very frequently I bought tons of craftsman and snap-on tools in the states cuz they were so much cheaper.
btw, the core value for the rear caliper is 50 Euro. You can get a freshly rebuilt one in the states for less.
So, for now I´m being cheap and will only replace the left rear caliper.
Summer: 1996 855 R
Donor: 1995 854 10V
