Trying to find answer to the gasket question above, the v70 diagram shows the gasket 17 but no part number given .....
DIY: 2005 Volvo XC90 Thermostat + ECT without removing PS Pump
- Been thanked: 4068 times
This is such a great write up of a real time saving procedure.
Volvo does not sell Tstat alone (some forums say it may be Gates TH35991 which may require modification before install), instead you have to buy the whole tstat assembly which includes: lower housing, upper housing, tstat itself, and ECT sensor....
www.routerlogin.net
pikashow
www.routerlogin.net
pikashow
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The thermostat assembly part #31293700 can be removed for servicing, reassembled with Permatex Water Pump & Thermostat Housing Gasket Maker. You are good to many years. Thinly coated screw threads are best before assembling.abscate wrote: 09 Dec 2023, 03:05 This is such a great write up of a real time saving procedure.
Trying to find answer to the gasket question above, the v70 diagram shows the gasket 17 but no part number given ..... :shock:
- 22 Replies
- 35958 Views
Last post by erikv11
- 1890 Views
Last post by 93Regina
- 891 Views
- 671 Views
- 241 Views
Last post by RickHaleParker
