Tried alternative 1 today with my XC90 and it worked right away! Thank you for posting this!dyn blin wrote:The P80 platforms are one of the early OBDII systems that may take some time to collect enough data to show "ready" for testing. Volvo's are not alone in this tendency, and some states maintain flexibility in testing protocols and readiness monitors. Maryland does not appear to be one of them.
Generally, the following driving cycle performed twice is sufficient to reset the monitors:
Start with the vehicle cool, below 122 degrees F.
Turn off the air conditioning.
Select a location where the driving can be done without violating traffic laws and you can stop safely at the side of the road.
1. Start the engine and accelerate to approximately 1500-2000 rpm.
2. Drive for 6 minutes at 1500-2000 rpm.
3. Stop the vehicle and remain at idle in drive for 70 seconds.
4. Accelerate to at least 45mph and drive for 5 minutes at 1800-2200 rpm.
5. Stop the vehicle and remain at idle in drive for 60 seconds.
6. Accelerate to at least 45 mph and drive for 4 minutes at 1800-2200 rpm.
7. Stop the vehicle and remain at idle in drive for 60 seconds.
8. Park the vehicle and turn off the engine.
Alternatively:
1.) Accelerate 0-50 MPH within 30 seconds
2.) Maintain 45-50 MPH for 20 minutes without using cruise control
3.) Park car turn off A/C idle for 5 minutes
4.) Accelerate 0-50 MPH within 30 seconds
5.) Maintain 45-50 MPH for 20 minutes without using cruise control
6.) Shut off car and allow to cool for 30 minutes before repeating cycle ( in some cases the car requires two cycles)
An OBDII reader is a must-have tool for any DIY diagnosis and repair, but unless there is a check-engine light, reading codes isn't your problem here, it's a lack of data from a recent reset.
"Not Ready" for OBD Emission test...? Topic is solved
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
BMW 540i 2002
S70 Base 2000
- dyn blin
- Year and Model: 1997 850 Wgn
- Has thanked: 1 time
- Been thanked: 2 times
'97 850 GLT Wagon- Driving to see 300k in the rearview
- Has thanked: 1611 times
- Been thanked: 4072 times
It must be terrifying when water comes from the sky instead of the faucet
- dyn blin
Indeed, hard to remember to keep the mouth closed so not to drown when we look up to see where the sun went...
dyn blin wrote:Indeed, hard to remember to keep the mouth closed so not to drown when we look up to see where the sun went...
Just like turkeys...
Hope you are all safe..
- 708 Views
Last post by bmdubya1198
- 1028 Views
- 4108 Views
Last post by precopster
- 233 Views
Last post by aeg
- 3307 Views
Last post by Sommerfeldt
