Serpentine belt does not fit Topic is solved
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
The good news is, you're not going crazy! Or maybe you are, now ...
Has thanked: 2199 times
Been thanked: 1852 times
They can be a challenge to fit when new as they are tight. I use the method mentioned and try to leave the belt slightly forward on any of the pulley wheels without a lip as this gives a fraction of extra length. I wish you luck! Having someone to hold the tensioner at max open may give you the extra help of having 2 hands to wrestle with the belt!
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
3 = 3 mm too short? That would do it.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Just to digress...
Whenever I install any new parts, I always check the new part against the old part before installation.
This helps avoid frustration, been there done that...
mydamnvolvo
Year and Model: Lots
Post by mydamnvolvo »
Serpentine belts used to fall of my van when I drove through puddles. I feel you. I, too, lose my mind over things like this only to be corrected by someone who sees the answer right in front of me. Good luck!
Current:
00 V70 (Daily)
01 V70 (Trips)
94 300zx (High School Present)
01 V70 (Hub)
08 GranCher (Daught)
01 740iL
09 C40 (Son)
Former:
93 BMW 525i-Daugh's-Seized
02 Chrysler T & C-Kid Hauler-Fire
72 Buick GSX-Dad's-Corroded
76 Golf GTI-Mom's-Died
97 960-1st-Timing
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Here is a copy of the email I received from a customer service rep from one of the main vendors:
"Hi Jason,
Sorry about that! I was just alerted via my purchasing guys that Continental sent us a batch of these belts that were labeled incorrectly and were slightly too short to install on the car. As we don't have any of these on the shelf and are still working this issue out with Continental, I can't just send you a new one unfortunately so I'm going to go ahead and refund you for the original purchase of the belt as it is incorrect. Sorry about that!
Let me know if I can help you with anything else, or if you have any more questions!"
This belt was wrapped in a Continental cardboard wrapper with "6K1743" printed on it, but the belt itself was stamped 6K1740. I didn't check the marking on the belt itself until after I had tried a few times to wrap it around all the pulleys.
AlanKot
Year and Model: 1998
Has thanked: 1 time
Post by AlanKot »
Hey guys,
Here is the update. New (correct) belt came in... 5 minutes and it was done. I really thought I was going crazy. Now on to the wife's XC - at least now I know what I am doing and I have the right belt. Thanks again for your help!
Alan
Post by erikv11 »
Thanks for the closure. Pesky!
cn90 wrote:Just to digress...
This is good practice but probably wouldn't help in this case. You're not likely to pick up a few mm difference in comparing belts by hand. Only way would be to think to check the part number on the belt, versus the number on the box/sleeve, like was posted about.
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
When I did my RN swap I fought with the belt for an hour gave up - the next am it slipped on in seconds-
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
I once fought with a PEX parking brake cable for something like an hour over a few days before noticing that the o-ring it came with was much fatter than the one on the cable that came off. Swapped the o-rings and the parts slipped right in.
