Guys...
Two days, two different belts (Dayco first and now Continental). Same size as the old belt but I cannot get it back on. I used the new routing and nothing. When I get to the last pulley its about an inch short. I even thought that maybe its too cold outside and it shrunk so I warmed it up and still nothing. Any suggestions? Thanks
Alan
1998 V70R
Serpentine belt does not fit Topic is solved
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Are you using a proper serpentine belt tool? You really have to get the tensioner pulled back all the way it will go for the belt to slide on. Easiest way for me is to get it all looped around and then slide it over the power steering pulley last. Make sure the belt isn't riding the lip of one of the lower pulleys and that there's no slack anywhere. I'm always surprised by how much of a pain the serp belt is.
If none of that works, then I'd assume you have an incorrect belt or that you're trying the routing wrong. What do you mean by "new routing"?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
I googled belt routing and I have it go around the crank, ac, up to alternator, down to idler pulley and up around the ps pump. When I get to the PS pump pulley (with the tensioner pulled all the way back) I need another 1/2 to 3/4 of an inch to slide it on the pulley. I am using Contitech 1743.
- Has thanked: 311 times
- Been thanked: 817 times
So are you using this routing? :
https://www.ipdusa.com/products/5656/10 ... 70-v70-c70
I put it around the idler pulley last.
Conti 1743 is the right number, you're good there.
Also what work did you do with the belt off, did any of those pulleys move (alternator, etc.)?
- Been thanked: 4064 times
They don't shrink in cold weather. Probably the tensioner isn't pulled fully in - its pretty tight. If it rides up on that little ridge on a pulley, it won't fit either...
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
If possible try putting it onto the smooth idler pulley last. You won't have a lip to fight. Whether you can reach your hand down there depends on what kind of tool you're using to loosen the tensioner though.
It's really easy to incorrectly fit it to the crank pulley and lose the slack there.
- 1272 Views
Last post by dm635
- 20 Replies
- 17344 Views
Last post by Hurtfeelings
- 21 Replies
- 5278 Views
Last post by viper69
- 22 Replies
- 35754 Views
Last post by erikv11
- 62 Replies
- 17739 Views
Last post by Shanestrait
