98 S70 N/A: Question about coolant and expansion tanks
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
rspi wrote: 12 Sep 2017, 19:53 I apologize for not reading all of the post but that really looks like oil. I would thing that either the engine is somehow leaking oil into the coolant system, or it's transmission fluid getting in through the rad. The thing about that is, if it's manual, there is NO connection to the transmission. If it's NA there is no oil through the radiator.
Send an oil sample to Blackstone labs. They will at least be able to tell you if there is coolant in the oil.
:cry:
I meant to send one off but by the time I remembered, all the oil was out already... This is where my engine was 10K ago.
Retired:
2015 Volvo S60, T5, 85K
rspi
Post by rspi »
Well, if you are loosing coolant fast, you can send a sample in as soon as you loose a bottle.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Always use Volvo coolant! There is a reason they have their own. If they were trying to just make money they would market their own auto trans fluid, brake fluid which they don't. It is a European formulation for European cars. Same goes for Japanese cars.
The all in one coolants are for cheap asses. Best saying: "don't be penny wise but pound foolish."
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
theWIFES_S70
mecheng wrote: 14 Sep 2017, 06:37 Always use Volvo coolant! There is a reason they have their own. If they were trying to just make money they would market their own auto trans fluid, brake fluid which they don't. It is a European formulation for European cars. Same goes for Japanese cars.
I know, I know... To be honest, based on June's recommendation, I'd change my coolant if I didn't have to wait until Spring to recycle it. (In NYC, you can only recycle coolant 4 days a year. And just try to get a mechanic to accept your old coolant!)
Without having this thread de-evolve into another coolant thread, I thought the coolants to use, in order of goodness, were the following:
1. Volvo
2. Pentosin
3. Zerex G05
5. Anything Green with a label
6. No-name green...
7. Distilled water
8. Water
Am I wrong here?
Retired:
Has thanked: 1614 times
Been thanked: 4078 times
Marco..drop coolant off up here, we can discharge into drains up here. No for that in NYC, of course.
DrJammer
Year and Model: 2000 V70XC - 195k
Has thanked: 1 time
Post by DrJammer »
I had a coolant tank that looked like that earlier this year. My radiator was shot. I was getting coolant into the ATF and something, ATF or oil, into my coolant. Replaced the rad with the Nissens and all seemed well until I noticed a slow leak. I just replaced the expansion tank with OE volvo, the old one had some cracks on the bottom nozzle. Come to find out I busted the sensor somehow. Just replaced the sensor with a URO in 5 minutes by the lift expansion tank and power steering box and replace method shown by abscate (showed my 5 year old too).
During that, I think the bottom coolant hose (P/N 9445378) had some cracking/weeping. It must have been the original spot of the coolant loss.
Can I get away with a URO hose for this or stick with OEM? Any thoughts on how to get enough coolant out to replace without draining all? I always use volvo coolant, and just replaced it 2x this year and I'd rather not drain the whole thing to replace this hose.
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
If I could get to both ends easily and I can inspect the hose totally, and were short on bread, I would use a URO here. It is still under pressure, but you are going to see any leak quickly from within car.
To replace - lift reservoir carefully and only enough to find the level sensor disconnect, remove it.
Now you can tip the reservoir enough to have the bottom nipple dry so you can replace the hose without draining coolant
mecheng
Post by mecheng »
theWIFES_S70 wrote: 14 Sep 2017, 20:48
1. Volvo
2. Pentosin
3. Zerex G05
6. No-name green...
7. Distilled water
8. Water
Am I wrong here?
Yes but I would only item 1 and 2. Zerex is not a direct copy of Pentosin. Price delta is probably a fancy coffee.
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
abscate wrote: 15 Sep 2017, 05:22 Marco..drop coolant off up here, we can discharge into drains up here. No for that in NYC, of course.
Just don't do that on my side of the river on a rainy day - as it will end up in the river after the plant has to go into bypass after exceeding capacity. =p
Makes for an interesting swim in the Hudson as well...
2023 Lexus RZ450e -66k
