Checking out a 2005 V70 Base
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Re: Checking out a 2005 V70 Base
Post by E Showell »
Jim -- I'm interested if you locate one.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
oragex wrote: 12 Dec 2017, 08:20
Rattnalle wrote: 11 Dec 2017, 23:10 Did Volvo seriously not bother to add the sway bar for non turbo cars for the north American market?
My 2003 n/a has it (all rusty, by the way) but it's a S60. Perhaps the V70 n/a don't have it. I've heard the V70 have a sloppier drive. I'd surely install one if possible (if subframe holes already there, no interference with exhaust/suspension parts, etc). A used one with good bushings and two new end links should be decent, the bushings on the rear sway bar last much longer than on the front one.
As far as I know all the cars are supposed to have it. Without it they don't work according to design anymore. That's why I questioned it. OP: Check that you really don't have one before looking for one. It's easy to spot. No sway bar - no swar bar links and those are clearly visible by just sticking you head to the ground behind the car.
A V70 has a bit more heavy glass in the rear and is a tiny bit longer than an S60 but the difference in drive should be small by design. However if a V70 has spent it's life hauling cargo and then you compare it to an S60 which probably hasn't there will probably be a noticeable difference.
E Showell
Post by E Showell »
Tack for det. Jag skall titta.
'95 855 auto (sold)
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 64 times
Been thanked: 69 times
Post by Georgeandkira »
I must do that to my car AND I already have the bar.
1) Raise rear and let the wheels "full drop".
2) Remove rear shocks. You need them gone so you can squirrel the bar between the coils.
3) Fasten clamps to the body then add drop links.
That's it, right?
850 LPT
Year and Model: 96' 850
Has thanked: 332 times
Been thanked: 243 times
Post by 850 LPT »
Still no photos of this beauty? :o
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
E Showell
Post by E Showell »
It has to be light out to take photos. I'm gone during daylight hours. Weekend. Promise.
'95 855 auto (sold)
Has thanked: 1511 times
Been thanked: 3829 times
Check out the wiring harness for the heated third seat...
E Showell
Post by E Showell »
Thanks, Steve. Pictures are from the Craigslist ad that drew me to the car in the first instance. Haven't had a chance to take any of my own. Tip of the hat to moderator abscate for posting.
'95 855 auto (sold)
E Showell
Post by E Showell »
Jim, a/k/a JRL, appears to be correct as far as rear sway bar goes. No evidence of same present.
'95 855 auto (sold)
It probably fell off and you drove by it. That's good, though, as you can't practice unless you pass the bar
