I'm always amazed when people talk about upper-class European cars, especially old ones that need a lot of expensive repairs, and mention fuel costs at the same time =)
Haldex Gen2 is bullet-proof. If only Volvo would move DEM to trunk like it did with PEM that was suffering from the same water penetration problems...
2003 XC70 - Loss of rear wheel drive (FWD only, AWD not working)
- Been thanked: 504 times
Nope,
This discussion has fuel mileage in the equation. Nothing to do with upper-end (expensive) vs cheaper vehicles. Basically, this is a "scientific discussion".
Haldex is not bullet-proof.
For winter safety:
- AWD + winter tires = #1
- FWD + winter tires = #2
- AWD + four-season tires = #3
I am happy with #2.
For me, I never care too much about AWD bc I always use winter tires for safety. I bought the 2005 XC90 AWD bc it was the only one available. When the sleeve stripped, it did not bother me. I am driving it as FWD, and yes fuel mileage improves after the sleeve stripped.
For winter safety:
I am happy with #2.
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
I purchased the Volvo pump on Amazon for $280.XC70Rider wrote: 28 Jun 2019, 10:02What's the VW matching AOC oil pump for our P2s? The cheapest Volvo AOC oil pump, 30783079, I can find is $280 on amazon.vtl wrote: 17 Dec 2017, 11:11 ..... Not too cheap, but you can get one for VW for 1/2 of price.
Also driveshaft is bad too because of age and mileage, it needs a new CV joints and at least a new rubber around center bearing.
P3 is worse than P2 all around, honestly.
Giving thoughts of throwing on a new AOC oil pump before my 12 year one starts failing. With a rebuilt driveshaft and new oscillation damper installed then installing a new oil pump won't be much of a hassle. Removing the driveshaft keeps getting easier each time.
Edit:
Is this the matching pump you're referring to?
https://www.ecstuning.com/b-genuine-vol ... av598549a/
https://www.amazon.com/gp/product/B00GN ... UTF8&psc=1
The mtaching VW/ Audi pump is PN 0AV598549A for $235. The pump is identical but the harness is longer and the harness mounting location is different. The casing would need adjusting to insert this. It mounts very close to the oscillation damper.
https://www.ebay.com/itm/152913388917?ul_noapp=true
Decided to pay $45 more for a direct fit OEM Volvo pump.
- 1021 Views
Last post by xHeart
- 2529 Views
Last post by ggleavitt
- 1585 Views
Last post by darylrobert
- 38 Replies
- 12197 Views
Last post by mrbrian200
- 22 Replies
- 1699 Views
