Glove still blows up after PCV repair.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
jeffsws wrote: 07 Jul 2018, 05:36 What a disaster. Done a dry compression test today in a warmish car (had to drive about 15mins to get there.)
1 ---- 2 ---- 3 ---- 4 ---- 5
130, 135, 140, 150, 135
Then tried for a wet test. Put some oil in 1 and when cranking the car the pressure maxed out... 300+.... And when removing it smoke was coming out of it and number 3. I may have poured too much oil in. I then continued to test 2-5 without oil and each jumped about 20psi anyway.
Doesn't look good to me...
You should never remove sparkplugs from a warm aluminum head. Engine should be cold to prevent thread damage. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Whoa, ease up there June!
Compression is tested on I will estimate hundreds of *warm* (even hot) aluminum heads every single day, all across the world.
Use a smidge of anti-seize on the plug threads and don't worry about it for a second.
jeffsws
Year and Model: 850 NA 1997
Has thanked: 3 times
Been thanked: 3 times
Post by jeffsws »
Okay, ran it again. Much cooler engine this time but not cold cold.
D: 130 140 150 155 140
W: 150 180 200 200 175
Didn't have a teaspoon handy but put in much less oil this time for the wet test.
Anyway, do those number say anything? I assume it's looking like new seals needed?
Has thanked: 1609 times
Been thanked: 4063 times
A bit of wear on rings but not too bad.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
June wrote: 07 Jul 2018, 15:16 You should never remove sparkplugs from a warm aluminum head. Engine should be cold to prevent thread damage. June
I've read the same.. especially when removing them for the first time in 10 years. Better just undo them first with a cold engine.
oragex
Post by oragex »
jeffsws wrote: 09 Jul 2018, 12:18 Okay, ran it again. Much cooler engine this time but not cold cold.
Possibly some stuck compression rings? Also read these engines are not that kind on the valve seats..
jeffsws
Post by jeffsws »
So given the numbers that would likely explain the blowback?
My T5 numbers are down to about 130 but I don’t have any PCV pressure
