Wheel bearing on 2004
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
Hub bolts Front- 987487
Hub bolts Rear- 987844
Caliper bolts Front- 987489
Caliper bolts Rear- 987488
Not sure where those hub bolts came from, they don't look like what I've replaced a couple of times on a couple of cars. OE replacement looks just like the OE bolt in the photo.
Axle bolt, can see a write-up on the size differences here- https://www.ipdusa.com/products/6250/113950-axle-bolt, both my cars have the longer bolt in them by design. I do not believe you can use the 65mm bolt if it's designed for the 45mm bolt, rubber spacer notwithstanding.
