ODBII diagnosis
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Sommerfeldt wrote: 12 Feb 2019, 15:51
Anyway, my point was that OP asked about flash tools, and that ELM is hit & miss for the 850. Some people get it to work, with the Torque app or other apps, some don’t. I’ve tried several times, and the best I could get was sporadic command line connectivity with pretty useless replies.
A lot of the cheap ELM237 are poorly done copies. One need to spend more to get a quality ELM327. Xiaotec recommends ObdLinkSX . I had good luck with a BAFX Products OBDII (a ELM327 clone).
If one does not have a Android device, one can use a Android emulator and host it on another operating system. I run Torque and 850 OBD-II on a Windows tablet with the Android emulator NOXPlayer.
Active
Past
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
misha wrote: 12 Feb 2019, 13:55 Those android apps are not accurate at all...they even tend to show non-existing codes in wrong modules...as it was shown with MVS member from France recently.
They are waste of time and they are misleading.
*shrug*
Mine has worked fine every time on the 3 cars I've used it on, and I've loaned it out to a couple friends to diagnose CELs on their non-Volvo cars. The 850 OBD-II has cleared service lights on both our cars recently, as well. Takes like 2 minutes. (Most of that is turning on BT and connecting to the reader).
RickHaleParker
Chuck W wrote: 12 Feb 2019, 17:57 Mine has worked fine every time on the 3 cars I've used it on, and I've loaned it out to a couple friends to diagnose CELs on their non-Volvo cars.
Which one are you using? It might help individuals that are trying to sort the junk from the gold.
Active
Past
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
I use the BAFX bluetooth reader
Chuck W
Post by Chuck W »
RickHaleParker wrote: 12 Feb 2019, 18:39
THIS ONE
Bought it over 4 years ago, so this one isn't available any longer. There are a couple similar-looking ones that pop up in related items.
It came with a disc of some sort, but I just tossed that in the trash. Plugged it in. Paired it via BT. Done.
gmh
Year and Model: 2016 XC60 T5
Has thanked: 28 times
Been thanked: 22 times
Post by gmh »
ZionXIX wrote: 12 Feb 2019, 18:47 I use the BAFX bluetooth reader
+1 Works great with Torque Pro and volvo850diag, haven't tried 850 OBD-II .
https://www.amazon.com/dp/B005NLQAHS/re ... UTF8&psc=1
https://bafxpro.com/products/obdreader
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
RickHaleParker wrote: 12 Feb 2019, 16:21 A lot of the cheap ELM237 are poorly done copies. One need to spend more to get a quality ELM327. Xiaotec recommends ObdLinkSX . I had good luck with a BAFX Products OBDII (a ELM327 clone).
That's a good tip - I hadn't seen that emulator before. I've a tiny old laptop laying around, so I'll set that up and check it out with one of those BAFX thingies. Thanks!
- S
[Sold] '97 S70 T5
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
I bought one of these. Low profile enough so that the center console isn't sticking up awkwardly while driving. Seems to be playing nice with Torque and 850-OBDII. Confirmed running ELM firmware 2.1, so it's either legit or a very good fake. With the multiple apps available on both Android and PC, this is way more useful than a cheap code reader.
RickHaleParker
If you are planning to use 850 OBD-II the ELM327 must be version 1.4b or higher. Stay away from the lowest bidders and stick with one of the reputable manufactures of ELM327 interfaces.
Active
Past
RickHaleParker
WhatAmIDoing wrote: 13 Feb 2019, 17:42 Confirmed running ELM firmware 2.1, so it's either legit or a very good fake.
If you can get the case open, look at the chips. Genuine ELM chips will be marked with the ELM logo.
Active
Past
