Last year 850s with M4.4 still use flash codes for ECC ONLY.
Everything is fully OBD II except ECC.
So...flash code reader will work on ECC.
S,v70 from '97 (transitional year from 850 to S,V70)got fully OBDII ECC and Volvo Scan tool is required for diagnostics.
LED code reader/ECC help
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- RickHaleParker
- Been thanked: 978 times
I know on the 960/S90/V90 with 4.3, 4.4, the ECC has a built in flash code reader for the ECC only.
Has anybody ever tried this on the 850 ECC?
SELF-DIAGNOSTIC SYSTEM
The EEC system incorporates a self-diagnostic function that indicates system faults through a series of trouble codes. The presence of fault(s) is indicated by flashing A/C OFF button. The control panel is programmed to enter a pre-programmed mode when a fault is detected. Under fault condition, control panel ignores the faulty signal, selects an alternative pre-programmed value and prevents delivery of faulty output signals.
Entering Self-Diagnostics
To enter mode, ensure engine is running. Shine a non-fluorescent, bright light on solar sensor. Place blower fan control knob in AUT position and function selector knob in vent position.
1. Place temperature control knob to maximum cooling (pointing straight down).
2. Ensure recirculated air switch is depressed and A/C OFF button is released.
3. Depress and release A/C OFF button within 5 seconds to start self-diagnostic mode.
Each fault code consists of 3 digits. For example, Code132 is displayed by a single flash of the A/C OFF button for the first digit (number 1). After a pause, the second digit of code (number 3) is indicated by 3 flashes. After another pause, the third digit of code (number 2) is indicated by 2 flashes. See TROUBLE CODE IDENTIFICATION table.
Three different fault codes may be stored in memory. However, only one code may be displayed upon request. It may be necessary to request display of fault codes a number of times to ensure all fault codes are displayed.
Exiting Self-Diagnostics & Clearing Codes
To exit self-diagnostics, turn ignition off. All codes are cleared when ignition is turned off. Fault codes are not stored in memory. Even if a code has occurred several times during a period of time, code will only be stored until ignition is turned off.
Active
Past
Past
- RickHaleParker
The solar sensor, combined with the theft alarm diode, is a photodiode which generates a current when exposed to solar radiation. In other words the blinking led on the top of the dash.
A led can be use as a light source or a light detector. When the anti-theif is armed it is used as a light. When the anti-theif is disarmed, it is used as a light detector.
This is how the Driver Information Module (DIM) knows when to automatically dim the dash lights.
Active
Past
Past
Doesn't this same sensor also serve as an input into ECC for solar heat load?
I didn't know they dual purposed the LED - thats clever.
- misha
No...no LED.
There is LED and solar sensor on that piece of plastic.
Led for Volvo Guard II on the top of it and solar sensor for ECC aside.
It's NOT for dimming the dash lights...at least on 850.
I have it...bought the car almost brand new and don't have that feature.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- RickHaleParker
"In direct sunlight, the temperature control dampers are positioned to provide a lower temperature, as determined by solarabscate wrote: 10 May 2019, 07:27 Doesn't this same sensor also serve as an input into ECC for solar heat load?
sensor input. If the engine is cold and outside temperature is low, the temperature control dampers are set for more heat to reach the
desired temperature faster."
LEDs have been used to build Poorman's Pyranometers.
Active
Past
Past
- 3275 Views
Last post by Sommerfeldt
- 2468 Views
- 20 Replies
- 4767 Views
Last post by smacknab
- 4906 Views
Last post by CRM
- 360 Views
Last post by jreed
