S70 T5 -- softer ride? tires?
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
When you look for rims here are the 3 main criteria with the bolt pattern being set (standard). Here is what was on my old S70 T5
http://volvo-wheels.com/product/volvo-s ... m-8622862/
Specifications
Hollander Part Number 70241
Volvo Part Number 8622862
Volvo Stamping Number 9173544
Bolt Pattern 5 x 108mm
Color / Finish Silver Bright (936)
Diameter & Width 15″ x 6.5″
Offset 43mm
Color Code 938
The offset is important but can be somewhat flexible as is the width.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Yes, the standard wheels from any 850 95 or newer or from any S70 will fit. And apparently any V70, certainly any V70 up to 2000. This is a really easy swap you don't need to get technical, though of course you can.
MoVolvos
Post by MoVolvos »
erikv11 wrote: 16 Nov 2019, 15:59 Yes, the standard wheels from any 850 95 or newer or from any S70 will fit. And apparently any V70, certainly any V70 up to 2000. This is a really easy swap you don't need to get technical, though of course you can.
mar601 wrote: 16 Nov 2019, 14:01 and I ask that because at Tirerack they show 15" available for the S70.
Those 3 specs in particular will help those looking for non-Volvo rims from sources such as TireRack.
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 46 times
Been thanked: 33 times
Post by Cees Klumper »
I went from 17 inch to 16 inch wheels on our 2001 C70 T5 for this reason but did not notice a big difference. Far bigger impact had the type shocks as another poster suggested. I found the standard Sachs touring type shocks much smoother than Bilstein HD's I had put on our S80 T6.
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Cees Klumper wrote: 17 Nov 2019, 05:01 I went from 17 inch to 16 inch wheels on our 2001 C70 T5 for this reason but did not notice a big difference. Far bigger impact had the type shocks as another poster suggested. I found the standard Sachs touring type shocks much smoother than Bilstein HD's I had put on our S80 T6.
I've tried both 205/55-16 and 225/45-17 on my P2 V70 and the difference was dramatic. I couldn't stand the 17" rims even though they look good on the car. However the step to 195/65-15 isn't as big though also noticeable on poor roads.
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
I have a 99 S70 T5 and a 1998 V70 non-turbo. They have different wheels and tires on them with the T5 having 16" wheel with lower profile tires, but I don't really notice any difference between the cars except for the T5 being much more powerful and seeming to cruise at a lower rpm for a given speed. The T5 ride doesn't feel any harsher to me. I would love to know if there were any real differences in the suspension components from the factory and also if there are differences in the gear ratios.
All U.S. market models.
All running and on the road.
Post by erikv11 »
Eddystone wrote: 19 Nov 2019, 15:46 ... I would love to know if ... there are differences in the gear ratios.
Yes, it is "well known" (but I'd have to do a search to recite the difference) that the turbo transmission has different gear ratios than the NA one.
Rattnalle
Post by Rattnalle »
erikv11 wrote: 19 Nov 2019, 16:26
Yes, in both auto and manual configuration. To use the low rpm torque of the turbo better. The NA would require a lot more shifting with the same gearing.
I don't think suspension differed much if at all until you get to the R versions.
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 273 times
Been thanked: 84 times
Post by hausmeister »
If the shocks/suspension is bad, different tires won't help a lot.
Maybe see if you can get the suspension tested if it is still good.
850 T5-R '95 auto Image
Eddystone
Post by Eddystone »
Rattnalle wrote: 20 Nov 2019, 02:26 Yes, in both auto and manual configuration. To use the low rpm torque of the turbo better. The NA would require a lot more shifting with the same gearing.
It is most apparent in highway driving when you go up a long hill. Even with the gearing it has, the non-turbo will often downshift from "top gear" in order to maintain speed in a position. I believe that you are right to reference torque, but it is definitely a "more power is better" situation. The turbo can gut out the hills, even at a relatively low rpm. If anyone is choosing between a turbo and non-turbo car, it's relevant that the turbo cars will be a little less strained at good highway speeds and run at a slightly lower rpm than the non-turbo cars. It's not a huge difference (a few hundred rpm) and the non-turbo is still a good highway car, but it is a few hundred rpm and the downshifting can be annoying (even if understandable).
I need to do a well-controlled test and see if the MUCH more powerful T5 gets better highway fuel economy. I suspect that it does.
