'98 V70 T5 won't start, P0301 & P0304
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
When you do the ignition tune up, check behind the dist rotor plate to make sure the cam seal is still place.
I missed it when was messing with mine, and then discovered a bad oil leak... Had to go back in and replace the seals. They were hard and weren't doing much anyway. I bet yours are similar.
- Has thanked: 311 times
- Been thanked: 817 times
Rear cam seal still hasn’t been checked ???
You are good there if you have put eyes on the cam seal and see it is installed and not leaking. Often a blown cam seal doesn't send in much oil, rather it is moisture from combustion gases that causes the misfires.
dmechnic
- Year and Model: 2004 V70 R
- Has thanked: 3 times
Thanks for nagging. Started to replace ignition components and when I pulled the cap guess what I found...little slivers of hard black plastic and oil residue. The car had idled for no more than 10 minutes since I had pulled and cleaned the cap before (no bits in it before). That "pop" and smoke when trying to start it apparently blew the cam seal completely out. Thanks for talking about it or I may have missed it since you don't have to pull the end plate/washer to change the rotor. New rear seals are being replaced...exhaust cam had some oil in it too but that seal was still seated. Changing nonetheless. Will know tomorrow if this fixes the issue. Thanks all for the help/input.
- Chuck W
That's exactly what mine did when it did the pop and smoke show.
Have you checked out that ECT sensor connector yet? Those suckers are a notorious trouble spot.
dmechnic
Got the new seals and ignition refuels done and she seems to be running fine. Checked and PCV system is working appropriately so hopefully it’s all set. Since I did plugs, wires, cap & rotor I can’t say with certainty which element was the culprit...for all I know it could have been a combination. Thanks everyone for the help on this. I’ll add an update in a few weeks to confirm resolution if it works out.
- 12 Replies
- 2545 Views
- 431 Views
Last post by rmmagow
- 1654 Views
Last post by RickHaleParker
- 483 Views
Last post by MoVolvos
- 2023 Views
Last post by Vovo_merz
