Volvo S80 T6 1999 bad start, bad idle after overhaul
Joost
- Year and Model: 1999 S80 T6
My parts supplier offered a photo with the different valve link styles. It looks like it's hard to mix up the rods of the valves, as it's hard to remove the spring from the first IMS version. However, I will open the transmission and check. I should be able to find the time next week, I will update here.
bronco
- Year and Model: 1998 V70
- Has thanked: 49 times
- Been thanked: 24 times
might as well do the electric checks on the solenoid , look at the harness and if you decided to pull the channel plate you could apply air pressure to those holes to check input , 3rd and second clutches and peek at the reverse bandJoost wrote: 21 Jul 2020, 18:08 My parts supplier offered a photo with the different valve link styles. It looks like it's hard to mix up the rods of the valves, as it's hard to remove the spring from the first IMS version. However, I will open the transmission and check. I should be able to find the time next week, I will update here.
bronco
Did you have this manual? It shows some specs for the different solenoids and that some malfunctions might not set codesJoost wrote: 21 Jul 2020, 19:22 Hey Bronco! I didn't have any fault codes in the transmission, but would you elaborate on the test that you mean?
https://shop.ukrtrans.biz/wp-content/up ... NDBOOK.pdf
around the 7:30 mark of this the guy does an air check
Joost
Thanks Bronco! I will have a look at the video. I had the ATSG original manual as well as the version with the updates, which goes a bit more into the Volvo boxes. I haven't had time to open up the box again, I hope to be able to next week. I did receive the following picture of the parts supplier (much appreciated!), which makes me think it would be hard to get it wrong, as the spring looks hard to remove from the rod, so you'll almost automatically pair the right valve/rod... But I will have a look anyway.
Joost
Hey Bronco, nice of you to check in! Actually, I've had some more urgent stuff to do these last week. I will pick it up as soon as I can. In fact, I really need my car back... I will update this thread with whatever I'll find.
Joost
Hi Bronco/all,
Sorry for not checking in for a while, it has been very busy. As I have holiday this week, I went working on the Volvo again. I was able to take the side cover of the trans off, with it still installed in the car, after removing subframe etc. The spring style valve I had installed, was still in place and seemed to be moving nicely along with the bracket from the gear lever.
Nontheless, I took it out and compared it to the clip style valve. It looks identical and also the overal length seems identical with the linkage installed. I've made some photos to clarify what I mean:
I installed the clip style valve, which also seems to operate fine.
I've made videos of both installments: https://photos.app.goo.gl/Qgx2fcXcYZBoJq2x5
To be honest, I don't believe this is what is causing the issue. There must be something else wrong. Any more suggestions? I could build it back and try, but I think it will be much work and no result...
- 615 Views
Last post by mecheng
- 3153 Views
- 849 Views
Last post by SonicAdventure
- 911 Views
Last post by fayed0903
- 13 Replies
- 2873 Views
Last post by Mr Wolf
