Failed glove test
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Re: Failed glove test
Post by Sveedy »
Compression test results :
#1 90lbs
#2 90lbs
#3 130lbs
#4 130lbs
#5 130lbs
Does this look like a head gasket issue, and maybe why I keep failing on the glove test ?
1999 V70 GLT
Sveedy
Post by Sveedy »
Those numbers are with the engine cold so I imagine it's a little higher warmed up. I'm leaning toward trying the seafoam treatment first in hopes that it might help before thinking about taking on the head gasket job.
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 999 times
Post by volvolugnut »
Did you try a small amount of oil in cylinders 1 and 2? This should seal rings if they are bad. You could also do the coolant test for exhaust gases.
Sveedy
Post by Sveedy »
I just put a little Marvel Mystery in #1 and there was no change at all. So she's warming up right now and I will check at warm temp. But I just checked again and there is no smoke what so ever coming out the tail pipe. She just sits there purring....
1999 V70 GLT
Sveedy
Post by Sveedy »
No change in compression at hot either. But I did notice a sickly sweet smell when I went into the garage, even with the garage door up.
1999 V70 GLT
I hope you have an alternate vehicle. I see head work in your future.
Has thanked: 1497 times
Been thanked: 3810 times
I would guess rings but if it smells sweet, you need a new gaskeet.
