Turns out the starting issue was a corroded wire from the solenoid to the starter, not sure why I hadn't checked there.
P0452 hasn't returned since swapping in the junkyard fuel tank pressure sensor.
Today i swapped in a new brake pedal position sensor and after 100 miles of mixed driving I no longer have a CEL or p1041 code and my cruise control is back.
More importantly my ETS light is gone! I read recently that the brake pedal position sensor going bad can trip the ETS light, atleast on a 99. I'll keep monitoring it but glad that this saga is tentatively solved.
Some of what tipped me off was when I brought my car to my indie to have them mate a new throttle body into the car. They said they tested my old one, and the extra backup i had in the trunk and they both gave the same readings as the new one.
1999 S70 Code ECM 4020, Cel, ETs..[solved by 9441116 brake position switch RR]
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
07 V50 T5 AWD M66 ~146k miles
He has tertiary Volvo disease....backup parts of backup parts.
- smacknab
Seems like there's no more topic is solved button, anyway to change the title to something like ETS light caused by brake pedal position sensor/p1041?
Part 9441116 if you have DTSC option on your car
$80 for the ATE version new, a good pick and pull item
- smacknab
Yeah I wish I went for the ATE one, for some reason I thought volvo electronics would be needed here, but the Volvo one is literally an ATE in a blue box. Better yet I wish I grabbed one off a junkyard car, probably would've cost me $5.abscate wrote: 01 Sep 2020, 03:39 Part 9441116 if you have DTSC option on your car
Thankfully I was able to return the new throttle body so I've saved a bunch of money on this and now I know my back up throttle body is good for the future too.
Only issue I'm still having is occasional hunting idle and the rpm still dips when coasting to a red light in neutral. Maybe there's some vaccine issue I'm unaware of?
UPDATE: RPM fluctuations were caused by cracked and disconnected crankcase vent hose. It was new so i didn't think it would be a problem, but it was a cheap one off amazon so turns out it was junk. I ductaped the cracks and got it back on and now there are no RPM dips while coasting and no hunting at idle. Will replace properly with a volvo one soonish.
- 315 Views
- 1146 Views
Last post by deardeergod
- 488 Views
Last post by lukask
- 3825 Views
Last post by PixelDust
- 5219 Views
