2006, XC90 2.5T no start , fuel delivery?
- Been thanked: 4067 times
That tool is brilliant. How did you get the spacing right on the teeth and what did you use to cut the slots?
betoarmenia
- Year and Model: 2006, XC90 2.5T
- Has thanked: 7 times
there are 18 eyelashes, just got the pvc piece over the pump and marked with a pen. Then everything done with a dremel.
Scraftatx2337
- Has thanked: 1 time
I also have 2006 xc00 2.5t and similar fuel delivery issues. Every time I fix one code, drives great for a day, an hour, a week and then a new, different issue/DTC appears.
I wanted to let you know that my xc90 has the PEM inside, 2nd row seats, passenger side. You have to remove the seats to access PEM and fuel pump.
I also have fuel pump relay in fuse box on engine compartment. My fuel pump connectors were causing o e of problems /codes so check those. Tomorrow I'm replacing fuel pump relay and main relay - both in engine compartment fuse box.
- 394 Views
Last post by cn90
- 29 Replies
- 5011 Views
Last post by 93Regina
- 1422 Views
Last post by mrbrian200
- 899 Views
Last post by lummert
- 1246 Views
Last post by skeeter506
