Brake Booster in-car seal replacement, question for Oragex
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
gnalan wrote: 22 Mar 2022, 16:18 Only turbo cars use a vacuum pump.
If I remember correctly, earlier turbos (MY01/02?) don't have it.
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
vtl wrote: 23 Mar 2022, 13:16 If I remember correctly, earlier turbos (MY01/02?) don't have it.
FCPEuro sells vacuum pumps that fit them.
vtl
Post by vtl »
gnalan wrote: 23 Mar 2022, 13:24 FCPEuro sells vacuum pumps that fit them.
FCPEuro is known to sell stuff that can't fit your car physically ;)
vtl
Post by vtl »
2001 V70XC 2.4T:
gnalan
Post by gnalan »
I didn't know that. I'm not even sure where the vacuum pump is located on the turbo cars. Mine is NA and puts out plenty of power for me to get around with.
Sorry if I mislead anyone.
vtl
Post by vtl »
gnalan wrote: 23 Mar 2022, 13:54 Mine is NA and puts out plenty of power for me to get around with.
Imagine torque you have at 4000 RPMs. Multiply it by ~1.33 and stretch evenly between 1500 and 4500 RPMs. That's 2.5T.
Imagine all the parts that break semi-often in your car, and maintenance items that you need to take care of routinely. Multiply their quantity by 3, divide average life span by 2. That's 2.5T AWD
Still miss my N/A 02 V70.
Has thanked: 1610 times
Been thanked: 4065 times
vtl wrote: 23 Mar 2022, 14:44
Multiply by 6 if driven by a male under 25 pre-brain operation
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
gnalan wrote: 21 Mar 2022, 15:24 If you're going to replace the brake booster you should replace the vacuum lines while it's out, too. You'll have more hand room to replace them, and one less thing to worry about in the future.
Preparing for the brake booster service. Am I to replace vacuum line 10, 18, 20 & 22? Would the hose from local O'Reilly suffice - what is ID?
gnalan
Post by gnalan »
I haven't replaced mine so I'm not sure. I think the ID is different that what you can get at a local parts store. I'd go with Volvo original parts to keep from having any sort of vacuum leak from the wrong size hose though.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
I also need to do mine. In as little as 10 minutes after stopping the car, the brake pedal is as firm as a rock. My other older volvo doesn't do this, there's vacuum there even after a few days or a week.
