I can't address your other questions, but left hand drill bits will make holes just as well as right hand bits made of the same material. I hope you purchased quality bits. Bits marked HHS for High Speed Steel would be the minimum specification. Try to lubricate and cool the bits with oil while drilling. If they get dull change bits to the next larger size sharpen the bit just like a right hand bit.
sheared subframe bolt '96 850
- Has thanked: 987 times
- Been thanked: 1078 times
jlp920
- Year and Model: '96 850, '95 940
- Has thanked: 5 times
That's helpful, thank you. I did get HHS bits that seemed like good quality.volvolugnut wrote: 23 Dec 2020, 13:37 I can't address your other questions, but left hand drill bits will make holes just as well as right hand bits made of the same material. I hope you purchased quality bits. Bits marked HHS for High Speed Steel would be the minimum specification. Try to lubricate and cool the bits with oil while drilling. If they get dull change bits to the next larger size sharpen the bit just like a right hand bit.
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
I had this happen on a left front subframe bolt once it was 100% IMPOSSIBLE to extract. I used the best tools and equipment available. IT would not extract. It would not drill out. Could not break it apart. Tight spot.... sheared bolt would not move no way no how. My solution was that I had an Really good WELDER weld in a threaded Stud. Hope this helps someone.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
volvolugnut's procedure is spot on -- hollow out one mm at a time.jlp920 wrote: 23 Dec 2020, 10:04 I remain grateful for your help.
I'm concerned about staying true with the bolt for the whole 50mm I will need to drill.
I'm also wondering about the effectiveness of using left hand bits for the whole process. Will they drill as well as regular bits?
Another question is the material I'm drilling into, what the inside of the frame looks like there...
is there room for error in case a re-tap is needed? My concern with drilling through the bushing is staying true in the bolt hole. I feel as though I'd be flying a little blind, so I'm leaning toward dropping the subframe. Thanks again for helping me to work through this, I'm still piecing it together through
all the suggestions I've received so far.
You're between a rock and a hard place. You'll know the level of difficulty in first 10 minutes of actual drilling.
Broken bolt length can be misleading. Compare it with the depth of the female thread on the good side to determine the actual length of task at hand.
jlp920
I started digging into the sheared off bolt with my new HSS left hand bits, just to see what I'm up against.
the bolt is actually not bad for drilling.
How does one sharpen a drill bit? Never done it.sharpen the bit just like a right hand bit.
Here is a good YouTube video on bit sharpening.
https://www.youtube.com/watch?v=uqPgdEThQzc
It takes some practice to do it well. Good news is you have a very long bit that is all the same shape and you can try to sharpen many times until you get it right. Just try not to get the bit very hot (bluing).
- RickHaleParker
- Been thanked: 980 times
The heat is easy to manage. Grind for 5 seconds then dip in Ice Water. Grind dip grind dip ....
Sharp point, with equal widths on either side. Do not change the angle of the point.
If you flat out ruin a tip you can cut it off with a Dremel and grind a new point. Make sure you get the new points angle correct.
Active
Past
Past
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Another cool video about drill bits:volvolugnut wrote: 29 Dec 2020, 12:47 Here is a good YouTube video on bit sharpening.
Skip to about thirty seconds in, and then budget thirty minutes 'cause it's a great video. The author makes a simple drill bit while explaining how a drill bit actually works. Not great as an instructional video for grinding them, but extra great if you just wanna learn more about drill bits!
- Has thanked: 1611 times
- Been thanked: 4075 times
Perfect application for your newly arrived Christmas present of a Dremel too and the 6700 drill guide ( I think)
If you have lots of drill bits to sharpen, consider the Drill Doctor product. It is fast and easy. Google it.
- 3690 Views
Last post by sleddriver
- 878 Views
Last post by leucadiacruiser
- 44 Replies
- 8288 Views
Last post by RickHaleParker
- 952 Views
Last post by GreenMagicMan
- 916 Views
