P80 Volvo 3D Parts Library Build
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 113 times
Post by Goupil »
I bought some 85A TPE, first time printing flexible filament, first attempt went really nice. Will make a few more and report back once installed on the car.
scot850 wrote: 13 Apr 2025, 17:34 I saw similar connectors on AliExpress with a connector that looks like the one that ones to the relay on the top of the radiator. I meant to buy a couple just to see if they are the same or would work for P80's.
I initially ordered some connectors from ali, the "standard" big 2 pin P80 ones can be found (only in pigtails).
Seller ended up cancelling the order due to supply issues, and this 3d printed option appeared in the meantime, so I figured i'd give it a try.
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
How are people modeling NLA parts that are warped / bent / cracked / shrunk over time?
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
BlackBart wrote: 18 Apr 2025, 15:13 How are people modeling NLA parts that are warped / bent / cracked / shrunk over time?
I suppose your only options would be pulling a better condition one from the junkyard, ebay or just trial and error in the modeling process.
crasbe
Year and Model: 02 S60, 98 V70 (EV)
Has thanked: 33 times
Been thanked: 82 times
Post by crasbe »
BlackBart wrote: 13 Apr 2025, 10:13 Would the resulting part be a soft pliable boot, or rigid plastic?
You can find more information about the seal in this thread here:
viewtopic.php?t=101867&start=10
The green one in the picture is made from PLA, which is hard, but the real ones were printed from TPU and TPE, which is soft.
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables :D
Has thanked: 2199 times
Been thanked: 1852 times
I just received my P80/P2 transmission axle oil seal set from V-Prints. Thy look really good. I now have to wait for an opportunity to use them. This though makes me realize that the one I really need is a seal installing tool for the AWD RH axle and sleeve seal.
