Purpose of this thread is to document post by post, ECU software IDs, ETM software IDs and report on compatability.
Lets try to take discussion to another thread for now.
See next post for format
ECU ETM software and compatability report Library
- Has thanked: 1613 times
- Been thanked: 4075 times
Obviously this combination worked.
This unit is an original MM from Volvo build date 98W032
- ECU software info
- 18280C70-9EBD-459B-A4C3-F01FD83C2F1B_1_105_c.jpeg (111.98 KiB) Viewed 12980 times
- ECM software info
- ABE695A9-50CB-4B6A-A8A9-683598A2DA82_1_105_c.jpeg (117.9 KiB) Viewed 12980 times
Here is a yellow Label from another 1999 S70 AWD that passed self test, shortly to be put on car for drive test
- Build label 2006 W07
- 09883D31-19DF-4296-8A9C-8D576483B2FC_4_5005_c.jpeg (42.57 KiB) Viewed 12980 times
- ECU software
- F38093AB-0FD4-45E7-BC8C-EB4D1B93D3FD_4_5005_c.jpeg (39.04 KiB) Viewed 12980 times
- ETM software
- EB234CF3-18B2-4B96-A6F3-FB2AF43B2FC0_4_5005_c.jpeg (38.94 KiB) Viewed 12980 times
This one is the late model contactless white lable
It did NOT pass self test on athe turbo AWD S70 - Is suspect it is a NA software unit?
ECU REV WAS SAME AS one in first post (same test car)
- 0C0E8665-7A52-404B-B15C-4B9FC375BC7C_4_5005_c.jpeg (42.29 KiB) Viewed 12980 times
- ECM SOFTWARE REV
- D3006734-4D6D-49A7-BFB6-E0038F1DF256_4_5005_c.jpeg (37.8 KiB) Viewed 12980 times
A third unit from a 2001 Turbo car
This unit DID pass self test on teh S70 AWD T3 engine , same test car.
- 895322A8-7B85-4AEE-9D68-CA9894D3B8C6_4_5005_c.jpeg (42.47 KiB) Viewed 12980 times
- B55BB37F-28B8-4ED0-8066-410FD2323B04_4_5005_c.jpeg (33.62 KiB) Viewed 12980 times
Moved to P80 forum for visibility.
Wouldn’t it be cool if we could ID which ETM software goes either which cars ??
See first post for instructions
- 24 Replies
- 6676 Views
- 12 Replies
- 3985 Views
Last post by precopster
- 1254 Views
Last post by LdeM
- 187 Views
Last post by radek93
- 1742 Views
Last post by the65dartguy1
