The 2099 patch?
VIDA 2014D_Repack install on Windows 10, any version.
- RickHaleParker
- Been thanked: 977 times
Active
Past
Past
GrumpyMonkey
- Year and Model: 2010 V70 1.6
Hello,
Has anything changed with this installation? I followed these instructions earlier this year or last (can't remember). It all worked first time. After months of occasional use, Vida would no longer see the dice, but the Dicediag had no problems communicating. Vida would log in, but the communications device bit in the top left corner of the home screen was gone and sometimes a missing object message popped up. Reinstalled the dice drivers and reenabled hosting, but nothing changed.
I have uninstalled Vida and installed again. Everything appears to install OK without any error messages. When I try to log in the box pops up with the progressing green band, but quits fairly quickly with no message and doesn't log in. If I put anything else in, other than admin, there is a contact volvo message.
Has anybody else's install failed after time, and if so, how did you fix it?
GrumpyMonkey
I forgot to mention,
"Unknown error:
Please contact your local Helpdesk
Could not contact central systems."
This message pops up when I try to log in.
"Unknown error:
GrumpyMonkey
"2099 patch with 280kb"
Is there a link to that somewhere?
Thanks
Thanks
GrumpyMonkey
Update:
I have now got the Vida installation back up and I can log in. I am back where I started. There is still no comms with the dice, communications tool section on the Vida start page is empty. The drivers are installed and hosting is enabled. The device shows no issues in device manager. I've no idea what else I can try.
GrumpyMonkey
Problem solved.
IE compatibility mode in Edge didn't work. I changed the default browser to IE. When vida opened, the Isoview splash screen showed and the dice was visible.
It all works again now.
sangcXL3
- Year and Model: 2006 XC90
- Has thanked: 1 time
Do you care to share on how u running the IE as default browser? Im currently experienced exactly like your problem. Vida does not detect the diceGrumpyMonkey wrote: 26 Jul 2023, 03:47 Problem solved.
Update: ive managed to run IE, but still, the dice wont detected.
- RickHaleParker
At the top of the instructions. It is 296K unpacked.GrumpyMonkey wrote: 23 Jul 2023, 08:59 "2099 patch with 280kb"
Thanks
Active
Past
Past
I just go a new vxdiag reader from aliexpres cause i lost the old one. With this new tool i get e error when reading the car on vida. The error is targetinvocationexeption. Anybody has any idea how to fix this? Thanks in Advance
- 11034 Views
Last post by Stasiuss
- 4923 Views
Last post by big305
- 5897 Views
Last post by RickHaleParker
- 3011 Views
Last post by rusty volvo
- 4388 Views
Last post by wizechatmgr
