P80 PCV System Repair on a Volvo 5-cylinder (-1998)
This topic is in the MVS Volvo Repair Database » PCV System Repair on a Volvo 5-cylinder
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
xHeart wrote:Would draining coolant few liters from the plug under the radiator eliminate the need of pinching bleeder hose, and any spill at removing upper radiator hose? Save and refill afterward.
Yeah, that'd help. Careful with that plug on the radiator, though - if it's an original Valeo OEM one that came with the car, the petcocks snap off easily with age.
'98 S70 T5
2016 Chevy Cruze Premier
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
I am about to start on taking down the inlet manifold. Would it be ok to drain the engine oil since change is due? Add oil and filter after it is all bolted back together?
Drained enough coolant that the expansion tank now looks empty.
I am having fun this fall morning.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
No need to do either. Just read and follow the instructions.
xHeart
Post by xHeart »
rspi wrote:No need to do either. Just read and follow the instructions.
The oil change is due. It is on ramp and accessible. Plus the new PCV will have a cleaner start.
What do you think?
jblackburn
Sure, won't hurt anything.
'98 S70 T5
rspi
Post by rspi »
Most people do change the oil after than do the job. I would do the job before I drained the oil.
xHeart
Post by xHeart »
I am with the program.
Is this the famous clogging of block?
this looks like my down spout on gutter after the Fall, start of Spring
Is it a roto rooter job??
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
Great write up brother...I especially like the pic of you standing in the engine bay. Doing this today to my wife's 850, it's doesn't need it bad but I figure at 100,000 miles it should be done. I swapped in the TBD from the 960 and the airbox thermostat mod. After the pcv system is done I'm changing out the oil for winter(Mobil1).
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
shiloh51933
I did this yesterday not realizing I had the wrong oil seperator box...I ended up just plugging up the flame trap hose where it would have connected to the oil seperator box. Yeah I was fuukin' pissed off...epecially since most of my good tools are at work!!
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
A few words on PCV Job.
Things have changed over the last few years, many Volvo dealers now sell parts at very competitive prices (sometimes even cheaper than aftermarket vendors! Stick to Volvo OEM parts because aftermarket parts are junk, they will crack in 2 years.
As long as you do your diligent research, you should have the correct PNs for all the odds and ends.
Examples of dealers:
- Waltrip Volvo in Nashville TN, give them your VIN number:
http://www.trademotion.com/partlocator/ ... eid=216970
- Superior Volvo in Kansas City:
http://thevpstore.com/
PS: Go to FCP to check for proper PNs for your car, there are slight variations between models:
http://www.fcpeuro.com/products/volvo-p ... bo-850t200
