I uninstalled SQL and went back through the installation, and now I'm up and running. Thanks for the tip!
Now hopefully it continues to work!
Vida 2014D Times out 12/31/2017 23:59 Topic is solved
- Has thanked: 316 times
- Been thanked: 531 times
Jonboy74
- Year and Model: V70 2.4T, 2002
- Has thanked: 119 times
- Been thanked: 15 times
HI Rick - I just ran through this and it went beautifully, however there is one step I suggest you add for Windows 10 Pro. I kept getting an error about port 80 being in use. For some reason the "World Wide Web Publishing Service" was enabled. This laptop was my son's and it was heavily restricted, so I'm not sure why WWWPS was enabled.RickHaleParker wrote: 19 Feb 2018, 11:21 On windows 10
1. Manually install .net framework 3.5.
2. Run scripts 1- 3, in the root directory of VIDA2014D_RePack.iso, one at a time.
3. Run the 2099 patch
4. Run Script 4
. Do not run Script 5
5. Reboot
6. Wait for Java to request a firewall exception.
7. Wait for Vida monitor to turn green.
If DiCE does not work correctly. Run DiCE setup in :\3PP\Products\DiCE\
Clean up: Uninstall Russian language Adobe reader and install English language Adobe reader.
Password: admin or 1 - 4 for specific Partner groups.
The easiest way to disable it is by launching MSCONFIG (yes, it still exists in Win 10), click on the "Services" tab, sort by service name, scroll down to "World Wide Web Publishing Service" and then uncheck the check box, and then click on "OK". I did that, rebooted, and then everything worked flawlessly.
Thanks!
Jonboy
Taskmaster
- Year and Model: 2006 XC70
Are there current good links to the software - edit, got the torrent, thx.
I have a Dice unit but lost the laptop I had the software installed to in a house fire. I tried to use a Virtualbox image I found from my Win 10 laptop but I'm not having success reading vehicle info or using the Dice "Test Communication Tool". I see the Dice tool and enable it for the Virtualbox but no go. On the Virtualbox machine Device Manager I see the Dice tool with an error the driver cannot start. Does the driver need to be installed on the host machine?
Does the host version of DOTNET matter with a Virtualbox image because I am on 4.0.30319.
b3nb123
- Year and Model: 2010 XC90
- Has thanked: 2 times
I've had my Vida for ages, and as most people it seems struggled to get it working!!
Now I need to get it up and running so I'm trying again, this thing is sapping hours of my time!!
I'm running it on a virtual machine, Windows 7 ultimate, IE8. I had to add http://localhost to my safe sites list (also disabled the protection) and now get the login screen. But that's just it - a login screen?
I've tried running the patch on page 1 of this thread, but get an error 'tskill.exe isn't a valid command' or somethign similar. then the installation seems to continue, but with no notification that it ever completed.
Any help? I'm assuming I don't need to register with Volvo to log in?!?
Any help appreciated, I'm finally getting close after a very long time!
- RickHaleParker
- Been thanked: 978 times
1. Are you running the patch in the virtual machine and not the host OS?
2. Ignore 'tskill.exe isn't a valid command', it is an artifact from the Windows XP era, the patch still works.
3 If you install 2014D_RePack you you don't need a virtual machine, install it native in windows 10, 8 or 7.
4. If you install it native in Windows 7, do the Chrome conversion. Then it will work with IE11 and .net framework 4.X installed. You will still need .net framework 3.5 installed.
Active
Past
Past
- RickHaleParker
Page 16 for links.b3nb123 wrote: 09 Sep 2019, 08:06 Could someone point me in the direction of the 2014D_RePack download?
Alternative: Manually add the torrent link to qBittorrent.
Copy the magnet link in line below to your clipboard.
magnet:?xt=urn:btih:1b2995ac6b8926893e3dea41c01ce92208b19c8d
In qBitorrent go to File on the menu then select Add Torrent link.
In the box start a new line and paste the magnet link from the clipboard.
Click download.
Similar procedures for other bittorrent clients.
Active
Past
Past
JoseBQ wrote: 17 Sep 2019, 07:26 Need again some help.
I have VIDA2014 working through Chrome, but recently DICE isn't working anymore.
What do you think that happened?
Why I was able to run VIDA with DICE before but I can't anymore?
By the way, when running DICE test, I get an interface test failure.
- RickHaleParker
Be more specific, what failed ?JoseBQ wrote: 17 Sep 2019, 07:27 By the way, when running DICE test, I get an interface test failure.
Did you use the standalone DiCE diagnostics or the DiCE diagnostics in VIDA?
Active
Past
Past
- 8049 Views
Last post by jonesg
- 5220 Views
Last post by matthew1
- 4525 Views
Last post by Liliflower
- 10324 Views
Last post by nickbw898
- 2757 Views
Last post by xiami
