bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Wow, that's nasty! They really should have installed cabin filters on all of these.
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
The antenna on my 99 s70 was no longer retracting so I decided to swap it for a fully functioning antenna from a 98.
And I discovered yet another difference between 98s and the 99-00 models.
The antennas are the same, but the drainage tube at the bottom of the antenna, the antenna mounting bracket and even the top nut/mount are different between the two years/generation of cars.
Thankfully, I could swap them all over from my broken 99 antenna to the 98 but I was surprised at how many changes there were on just the antenna.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
matthew1 wrote: 30 Jun 2019, 18:09 Fixed the resistor pic at the cost of being able to click on it to get a larger version. Sorry about that.
That's ok. What is your process for fixing it? I tried using a photoeditor to rotate and save the picture. From now on my camera button needs to be on the right for landscape to be in the correct orientation.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
You have to strip the EXIF data that rides along inside the file. I Export in Photoshop to achieve this. There are probably a few dozen ways (apps) to do it.
Also -> Amazon link
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Using a "dumb" editor like MS Paint usually works for me.
Has thanked: 1609 times
Been thanked: 4064 times
ZionXIX wrote: 30 Jun 2019, 11:43 Good Sunday all,
Since were on the subject of AC systems. I'm in the middle of replacing my blower motor and resistor. While doing that I decided to shop vac around the evaporator a bit. This is actually the first time I have ever physically looked at the evap and I this vehicle has gone 23 years without a cabin filter. Why didn't volvo make this standard? A shop vac is only able to do so much. The crud I'm pulling off is well adhered to the evap fins. I'm impressed any air was getting through. Pics below to completely disgust your Sunday out.
Are you still getting AC with the corner of that evap munched by AC sharks? Incredible.
ZionXIX
Post by ZionXIX »
abscate wrote: 01 Jul 2019, 04:54
Still ice cold. I'm impressed to say the least.
matthew1
Site Admin
Post by matthew1 »
Ice cold? Yep, incredible.
Also -> Amazon link
Ah, looking closer what I thought was a gnawed evaporator is in fact a bar code sticker.
It is still impressively gunked up.
ZionXIX
Post by ZionXIX »
Yeah I removed that too. And for some reason a lot of paper straw wrappers.
