Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
jonesg wrote: 11 Aug 2022, 17:59 Replaced the leaked tranny fluid, i only measured half a cup when the lower cooling pipe was pulled from the radiator, thats all I put back.
I found it easiest to pump it back in the top cooling hose rather than mess with the dipstick hole.
Pump conveniently threads on the top of a soda bottle, same threads as quart of oil.
never bothered measuring the fluid hot as it shifts fine and i put back the same as came out so...
Don't know how the pic got rotated 90 degs.
Is that an internal combustion powered bicycle? :o
08 C702.5T (sold)
The non-Swedes:
Willber
Year and Model: 2.4t 2002
Has thanked: 5 times
Post by Willber »
Replaced the front and rear hydraulic engine mounts which were the last if the ones to change. I should have done this sooner as it has made a big difference to NVH. The old ones hadn't leaked but were collapsed and cracked and the wire rope was very baggy!
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Krons wrote: 17 Aug 2022, 20:53
[/quote]
Gas-powered stereo.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
yep, infernal combustion engine on a walmart beach cruiser.
4 stroke, 49cc, conversion kit from bike berry.
jonesg
Post by jonesg »
ran the car off the ground , traced the noise to front bearing ( I hope).
jonesg
Post by jonesg »
br0dy519 wrote: 17 Aug 2022, 18:48
jonesg wrote: 09 Aug 2022, 14:19 I have same noises in my front end, sounds like something rubbing, checked dust shields etc, I think i'll let it ride til it gets unmistakable
or run it on front jackstands and listen with a stethoscope. Haldex fuse is pulled.
Is your noise sort of harmonic depending on vehicle speed, with intermittent vibration? I rode in the passenger seat today (is there anything more emasculating than being driven around by your wife? :lol: ) and it honestly sounds like the wheel bearing on the passenger side has gone too. Noise increases when braking or putting load on the right side. What a bugger!!!
use a $12 stethoscope, you can hear it clear as a bell just turning the hub by hand.
good excuse to buy another tool too.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
jonesg wrote: 19 Aug 2022, 08:00 use a $12 stethoscope, you can hear it clear as a bell just turning the hub by hand.
I’ll try that. If i recall theres a little bit of brake drag noise that impedes my ability to hear anything else with the wheel off. Stethoscope is $7.50 this week on sale! Sweet
04s60 2.4
04xc70 2.5t
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
So hard to tell on those wheel bearings, I just went through this and replaced both of them. FYI I found the best price on FAG's at RockAuto.
2003 XC 70 (sold)
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
I broke the shift lock button on my automatic V70. I had repaired it with super glue years ago. I can still shift, but the button hangs out.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
scot850 wrote: 14 Aug 2022, 19:33 Not really, they had used some clear coat of some sort on them at some point which was a swine to remove. only way to get neat the edges on the XC was to remove them. I took the opportunity to swap all the minor bulbs out at the same time as the 2 that were out could not be removed otherwise. It was when I discovered the RH outer marker light is the only one that rotates counterclockwise to remove!!
Well Scot, since you pushed me I took the front bumper skin off today :lol: . I had no idea how easy this job is, and I really had no choice because I have to replace the windshield washer reservoir since it is leaking. There is simply no way to get to it this otherwise and now I can replace all the little headlight bulbs easily as well.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
