Has thanked: 2200 times
Been thanked: 1852 times
Thanks for confirming this. I always wondered if this could be done, but wasn't sure.
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
XC90 but a P2 nonetheless. Finally had the car long enough to pull the front floormats and inspect the aftermath of sunroof drain issue the previous owner let go. Had to run a heater on the foam overnight to thaw and dry. Forgot to snap an after picture...a coat of corroseal did a nice job sealing up the floor. Thankfully the passenger side (including yaw sensor) was dry as a bone.
Floor before cleanup and rust converter
Foam before cleanup
Foam before cleanup
08 C702.5T (sold)
The non-Swedes:
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Holy Odin! I thought my car (its transplanted donor chassis) was rusty!
Krons
Post by Krons »
vtl wrote: 28 Dec 2022, 14:14 Holy Odin! I thought my car (its transplanted donor chassis) was rusty!
Fortunately just surface rust. These XC90s have the unique opportunity to rust from the inside to out! :lol: Big issue is once the moisture is down there the foam is so thick and formed to the body there is no way to dry unless you pull the carpets.
When I bought it the a-pillars were pretty bad (now replaced) so I knew I was taking a risk. So far other than replacing the a-pillar and sunroof drain hose only other problem was a connector I needed to wire around.
08 C702.5T (sold)
The non-Swedes:
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Replaced all 5 coils with new Bosch units and Volvo OEM spark plugs and got rid of my misfire. I’ll save the 4 good ones for spares. Also changed the oil filler cap seal. PCV system overhaul next when I have some time now that I have all the parts for it.
2003 XC 70 (sold)
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
MDK here. So, I decided to check my spark plugs. I put new ones in about 7 months ago ( I barely got the old ones out) anyway.. I found this on #4 coil wiring assy. Someone had heat shrinked all 3 wires together. I separated them and re wrapped em. Dumped the oil, new 5w30 plus moly lube and filter..
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
MDK wrote: 31 Dec 2022, 15:13 MDK here. So, I decided to check my spark plugs. I put new ones in about 7 months ago ( I barely got the old ones out) anyway.. I found this on #4 coil wiring assy. Someone had heat shrinked all 3 wires together. I separated them and re wrapped em. Dumped the oil, new 5w30 plus moly lube and filter..
Was that causing a misfire?
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Replaced a seized brake caliper.
04s60 2.4
04xc70 2.5t
MarekDenn
Year and Model: 2003 V70 T5
Post by MarekDenn »
Today I figured out how to completely disable the traction control system, while retaining abs function. I’m finally able to have fun on the twisty snowy roads!
Krons
Post by Krons »
2008 S60 got some attention today. Was a tad slow to start and some stumbles on starting recently. Decided to replace the starter given it has 150k miles and with an online code was only $135 at Carquest for a lifetime warranty starter. Pretty easy access when you pull the intake pipe and spin the air box out of the way. Starts much better now.
While I was there replaced a bunch of brittle conduit wrap on harnesses to keep them out of harms way. Then to prevent any starting issues did the steering lock-ectomy to remove the failure prone steering lock mechanism. Now onto cleanup of the newly acquired 2008 C70…
08 C702.5T (sold)
The non-Swedes:
