Vida CEM swapping
matija0610
Year and Model: 2003 S60 D5
Has thanked: 21 times
Been thanked: 13 times
Post by matija0610 »
8-bit SUM whole CONF block
I think everything is clear in the picture ;)
ele288
Year and Model: s60 2.4
Post by ele288 »
Thank you, looks simple. What editor are you using?
matija0610
ele288 wrote: 08 Oct 2022, 02:44 Thank you, looks simple. What editor are you using?
HEX Workshop
ele288
Post by ele288 »
Thank you. I'll try and report the results
oscilloscope
Year and Model: 2005
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
ele288 wrote: 07 Oct 2022, 16:09 You can use cem cracker or read directly from cpu and find the pin. If you look at page 9 there is details where the config is, but if you change any byte you have to recalculate checksum but can't figure this out yet
Page 9 From what the microcontroller datasheet or something else ?
ele288
Post by ele288 »
Page 9 of this thread
5ft24
Year and Model: 2005 XC90 V8 AWD
Has thanked: 20 times
Been thanked: 12 times
Post by 5ft24 »
vtl wrote: 27 Sep 2022, 16:35
konielian wrote: 27 Sep 2022, 13:32 I am also interested on making an app which can write back by DiCE the modified flash into the car, thanks to T5Luke, on 28f400 cem that is possible but in the M32C CEM is still not solved.
Solve it! ;) Register at Renesas web site, download M32C datasheet and development environment. Renesas E8/E8a is slightly over $100 on Ebay. You will need a donor CEM, too. Once you have a flash-writing SBL ready, you are basically done. The CAN proto is very simple and wouldn't take long to implement.
Registered on their site. No datasheet for the M32C, and can't find a dev environment to dl there either
5ft24
Post by 5ft24 »
Finally found the HEW/compiler/debugger etc, but still no data sheet for the M32C
oscilloscope
5ft24 wrote: 08 Oct 2022, 16:18 Finally found the HEW/compiler/debugger etc, but still no data sheet for the M32C
Are you refering to the older brick style cem with the MC68376 ? Or is there another one which uses the 400 flash memory externally?
oscilloscope
Is this what you're after?
REN_rej03b0047_32c84ds_DST_20050708.pdf
(903.63 KiB) Downloaded 177 times
