Obd port turned up today. So I figured I'll give some twisted wires ago and see if it makes any difference I'll I await the other transceivers to arrive from the states.
Vida CEM swapping
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
oscilloscope
This memory fault appears when I compile ? But doesn't appear to impact the functioning of the tool. And there is also encryption file missing ? Is that something I Need ?
oscilloscope
so following on with the cracker. i did notice it only finds the CAN LS not the CAN Hs , so i am assuming i am having a connection error with the CAN H signal. i'll check over my wiring again. then again it may well be somthing to do with the CAN shark all in one modules i am using. so it is hardly surprising i'm having issues but it's a wild guess. at this stage.
it didn't decode it again , next time i'll take a pic as the error doesn't really make much sense.
liyezhu
hello everyone
I have a way to quickly solve P1, P2, P3, and CEM PINs. If you need help, please contact [removed]
5ft24
- Year and Model: 2005 XC90 V8 AWD
- Has thanked: 20 times
- Been thanked: 12 times
Ah yes. A scammerliyezhu wrote: 18 Oct 2022, 20:54 hello everyone
oscilloscope
- RickHaleParker
- Been thanked: 980 times
If he is a scammer, he just blind cast fishing. He should of been able to see we make poor Marks.
If he had taken the time to read this and think. He would of realized this is a DIY form. People that do DIY are not looking for quick solutions. They are looking for a DIY ( Do It Yourself ) solution. The fact that this thread is 243 pages long, so far, is proof of that.
It is a Mark's own greed or laziness that enables a scam to work.
Active
Past
Past
liyezhu
Don't judge others blindly. Give your VIN and let you know the result in 5 minutes. Unable to reply in time due to time differen
@ 5ft24
@ 5ft24
5ft24
No one cares. You are scamming the group. This isn't a forum to advertise in. It is a forum for people to create their own methods. Go peddle your crap elsewhereliyezhu wrote: 19 Oct 2022, 07:02 I solved the PIN code for the friend's two cars. You can ask him if I am a liar
- 9465 Views
Last post by RickHaleParker
- 9556 Views
- 27 Replies
- 29554 Views
Last post by cn90
- 11119 Views
Last post by jonesg
- 6226 Views
