I've used Marvel's mystery oil in the past for a few oil changes to get the sludge, etc cleaned up. I've also used it on my hands to remove really nasty road grease. As best I can tell it is one heck of a detergent.bmdubya1198 wrote: ↑10 Oct 2019, 17:43The oil drained out pretty clean, no sludge there. It was dark, but nothing abnormal. The only thing out of the ordinary was the sludge in the filter.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
- Has thanked: 304 times
- Been thanked: 517 times
I've been really happy with Marvel. I use it to free up seized engines, and I've also used it as a fuel treatment (works pretty well) and an an oil additive (seems to clean really well). I've noticed really surprising results from using in my my lawn mowers. One of my mowers runs MUCH smoother with a little bit of MMO in the tank!wizechatmgr wrote: ↑11 Oct 2019, 21:16 I've used Marvel's mystery oil in the past for a few oil changes to get the sludge, etc cleaned up. I've also used it on my hands to remove really nasty road grease. As best I can tell it is one heck of a detergent.
I found a Hidden Hitch at the junkyard yesterday for the XC90, bolted right on easily! An absolute steal for $28!
So naturally, I went and bought a hitch this morning and rented a dolly to go pick up my newest project.
The V8 did really well! Pulled the S70 with little effort, it felt like my cousin’s old F-150 when we pulled the 850 home. The brakes got a little hot as I got close to home (only a 30 minute tow) but I need to check those out again anyway. I just changed all four rotors and pads a couple weeks ago but I haven’t been happy with the pedal feel. Probably needs a bleed, I doubt the original fluid has been flushed out more than maybe once at 160k miles.
Tore into the S70 after finishing up a basically complete stage 0 on the 940 (which still has some squeaking pulleys... I'll investigate further tomorrow once it stops raining). Went to do a leak down test and discovered LOTS of coolant in cylinder 3. Definitely a bad head gasket!
I was really hoping that it was the oil cooler somehow, but I know those don't fail often at all.
brunocerous
- Year and Model: 1998 V70
- Has thanked: 284 times
- Been thanked: 36 times
Peeked under the hood of the T5 to show my brother a crumbling polyurethane upper engine mount that the PO had installed, only to find that it had completely disintegrated. Amazingly, he had a spare one along with the press to install it.
He also checked Blue Steel, which had a bit too much play in the steering wheel, and discovered a floppy sway end link. Dry rot. He had a spare one of those, too.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
That's why I only use good quality name-brand torque mount bushings!
He sure does! He showed up prepared!
- wizechatmgr
Replaced top torque mount with OEM Hutchinson. The poly one was torn to bits after being in just about 2 years.
For anyone wondering, the long bolts go towards the crank pulley.
- Has thanked: 1505 times
- Been thanked: 3818 times
wizechatmgr wrote: ↑14 Oct 2019, 21:31 Replaced top torque mount with OEM Hutchinson. The poly one was torn to bits after being in just about 2 years.
P80 part change on the upper mount from -1998 to 1999- The bastards get the all cast metal housing type.
