The Electrical Wiring Diagrams (EWD) 2005-2014.
You cannot "install" the repack version in Vida. If you want the Electrical diagrams on your hard drive. Copy the contents of the iso to a folder on your hard drive then bookmark index.html in your web browser.
EWD2014D_RePack.iso
Copy and paste the magnet link below to your bittorrent client.
magnet:?xt=urn:btih:3C85707FAF16DB2424E573B38998765F87CD5692&xl
Vida 2014D Times out 12/31/2017 23:59 Topic is solved
- RickHaleParker
- Been thanked: 979 times
Active
Past
Past
rjj100
- Year and Model: 2007 S60 2.5T
My system:
Windows 10 Pro, fresh install
16GB Memory
I installed successfully following carefully the instructions.on page 1 for the repack of the DVD.
The VIDA monitor in the tray shows running status (green).
I get the chime and see the device installed when I plug my DICE into a USB slot.
I made the conversion to run Vida All-in-One Chrome.
When I start Vida All-in-One Chrome and attempt to login by putting in 1 or admin, I get the bars showing progress but then I get this error:
Help is appreciated.
16GB Memory
I tried rerunning the 2099 patch again but still get the same result.Unknown error:
Please contact your local Helpdesk
Could not contact central systems.
- RickHaleParker
The last line "Could not contact central systems" is the clue. The patch fakes the central systems so that it can run without any central systems. It is not patching correctly or the configuration is incorrect.rjj100 wrote: 18 Jan 2020, 21:03
Did you install Vida all in one?
Location set to internet?
Rebooted after Vida install or reboot later?
Active
Past
Past
rjj100
I rebooted after running script 4. I did get the firewall exception earlier than stated and approved it.
On windows 10
1. Manually install .net framework 3.5.
2. Run scripts 1- 3, in the root directory of VIDA2014D_RePack.iso, one at a time.
3. Run the 2099 patch
4. Run Script 4
. Do not run Script 5
5. Reboot
6. Wait for Java to request a firewall exception.
7. Wait for Vida monitor to turn green.
On windows 10
4. Run Script 4
5. Reboot
- RickHaleParker
Open Microsoft Internet explorer. Make sure add-on WebCGMHIprObj Class is installed and enabled. Try to login in with Internet Explorer ... Not Microsoft Edge. http://localhost/Vida/
Active
Past
Past
rjj100
Thanks Rick,
I don't have Microsoft Internet Explorer 9 and cannot find a download. I could turn on IE 11 Windows feature. Do you mean with IE 11?
Can I run some SQL to check the DB and see where it points to the server?
Which script sets the address of the server to the local host?
Can I rerun that script again?
- RickHaleParker
The instructions say it works with Internet Explorer 9, does not day it must be Internet Explorer 9.rjj100 wrote: 19 Jan 2020, 09:30 I don't have Microsoft Internet Explorer 9 and cannot find a download. I could turn on IE 11 Windows feature. Do you mean with IE 11?
The instructions say you can upgrade to Internet Explorer 11.
You must have some version of IE install because, IE Tab uses Internet Explorer's rendering engine and ActiveX functions.
Turn on Internet Explorer 11 in features.
Active
Past
Past
rjj100
I turned on IE 11, and verified it has the extension WebCGMHlprObjClass installed and enabled.
I pointed the IE 11 browser to http://localhost/Vida/ and was presented with the Vida logon screen. Entering a Username of 1 resulted in the same error as before with Chrome.
Unknown error:
- RickHaleParker
You did the VIDA install without IE installed, which is a prerequisite.
Run scripts 1- 3 and the 2099 patch then script 4 again.
Active
Past
Past
- 8093 Views
Last post by jonesg
- 5259 Views
Last post by matthew1
- 4566 Views
Last post by Liliflower
- 10370 Views
Last post by nickbw898
- 2789 Views
Last post by xiami
