Awesome - glad to hear everything worked out well for you!akgyger wrote:Hello!
First post here at MVS, and I just wanted to say a major THANK YOU to Justin for this writeup. I performed the PCV job over the weekend in about 5 hours using OEM parts. Was able to get to the 12mm bolts from up above, did not remove coolant hoses, fan shroud, and i found that this service had been performed in a half-assed manner in the past, using URO hoses. The oil ports were clogged, the original box was still on the car, and the PTC was completely clogged. Also, I was fortunate enough not to drop manifold bolts during re-installation.
When I finally got the car back together, I was very happy that everything fired up, ran perfectly fine, and I no longer have a smoking dipstick. No check engine lights, blown off hoses, and no reason to go back in and re-do any of my work so far after 100 miles post-service. I would also like to thank CN90 for the 5/8 ID PTC hose (for lack of the actual part name) idea, I implemented it as well!
I used to be a huge advocate over on the brickboard when I owned an '86 245DL wagon (with a 302 swap!) Now that I'm the proud owner of a V70 ten years later, I feel that MVS is THE BEST site dedicated to repair and information of our beloved bricks.
Thanks everyone.
Andrew Gyger
P80 PCV System Repair on a Volvo 5-cylinder (-1998)
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
drgswede1978
- Year and Model: XC70 1998
Done this today using the ipd kit. All original volvo gear as far as I can tell. Thanks for the write up took about 4 hours all in with no problems. And the smoking dip stick is gone
JRL
- Year and Model: Several
- Been thanked: 16 times
Excellent
You guys are getting good at this!
I have a 2006 XC90 2.5T. Is there a trick to removing the lower left flame box 10mm bolt? I can't get a wrench or socket in there. Doesn't look possible unless you remove the alternator/power-steering/etc including the accessory rail bracket that mounts to the engine block.
$25 PCV breather hose turns into an 8 hour job and $300+ in parts!!!
Thanks!
Thanks!
iceracer
- Year and Model: v 70 1998 N/A
I just did the nitrile glove tie wrapped over the oil filler opening. when I increased the RPM on the motor, the glove sucks into the opening and when it was idling the glove kind of pulsed a little then just lay there not doing either blowing out or sucking in.
I put some drywall tape around the cap and after only an hour or so of driving, it has oil on on it.
I put a balloon over the dipstick and nothing happened at all, it smokes a little, but I had just returned from a brief trip, the engine was well warmed up, so its no surprise to me that smoke is coming out of there, that oil is really hot.
I'll get a new gasket or a new filler cap and see if that helps to resolve things.
jblackburn
If it's a turbo, clean the PTC nipple and make sure the vacuum line to intake manifold is intact. If it's a non-turbo, clean the flame trap and make sure the vacuum hose is intact. Either, put a new oil cap seal on it - these wear out often. Otherwise, your system sounds pretty good.iceracer wrote:I just did the nitrile glove tie wrapped over the oil filler opening. when I increased the RPM on the motor, the glove sucks into the opening and when it was idling the glove kind of pulsed a little then just lay there not doing either blowing out or sucking in.
'98 S70 T5
jblackburn
'98 S70 T5
- Has thanked: 311 times
- Been thanked: 817 times
With the flame trap disc itself, the little disc with all the holes in it, located inside the flame trap casing: throw it away.
- 1357 Views
Last post by JIMMYCNOTES
- 1593 Views
Last post by CIK7
- 865 Views
Last post by aartzer
- 2557 Views
- 2889 Views
