Did both boots on an NA yesterday afternoon, using the part numbers in the original post of this thread, one GKN outer and one GKN inner. The job went well and the parts fit perfectly. Sourced both parts from AutoHausAz.
The inner boot comes with 160g of grease (2 packets at 80g each), the outer with 80g and an axle nut. I used about 140 on the inner and the rest on the outer.
Volvo 850 Outer CV joint interchange data
Volvo 850 CV Joint info
- Has thanked: 311 times
- Been thanked: 817 times
- Has thanked: 2200 times
My head was spinning after reading all the input on this thread. I'm ok with the outer CV boot for my 97 850 NA auto, but did we come to a final conclusion on the inner CV boot from GKN Lobro part #?
I contacted FCP and they only supply the outer for the auto and only have the manual for the inner. Question, what are the measurements for the manual inner v's auto?
Thanks,
Thanks,
- Been thanked: 504 times
I need help from northerlights or any CV boot guru.
1998 S70 GLT with 180K miles.
Last rebooted at 90K, it is now at 180K, Left OUTER CV boot just cracked, spilling grease.
I already have the GKN 300439 at home but I need to buy an INNER Boot.
Just got under the car and measured the metal shaft: ID = 24 mm, OD = 92 mm for both INNER and OUTER CV Joints.
My question is for INNER Boot. Per northerlights, he used GKN 300597 (ID 21mm, OD 82 mm)!
See the photo I just sketched to show how northerlights did it, I wonder how you can expand a boot with 82mm into a ring with 92 mm?
PS: Volvo still sells INNER boot for Turbo axle, PN 31256230, about $34 or so.
UPDATE:
I decided to be the guinea pig re GKN OUTER for INNER side. It was a no go!
I ordered another GKN 300439 to test if it fits the INNER side:
- It is a bit loose (slightly bigger O.D.) but that is not the problem.
- The problem is in the "lip" profile (cross section profile), it does not fit very well b/c of the lip profile.
- So maybe nothernlights' idea of using Audi INNER boot for Turbo INNER side was OK (he said it was a tight fit).
I am glad I didn't cut the factory inner boot. I saved it and re-used it, it was still in decent shape.
However, your best bet is to ask nothernlights re Audi boot or better yet, cough up $35 and get the Volvo Inner boot from dealer.
Since this is the inner side and not subject to constant flexing/bending as seen in the OUTER joint, you may be OK with EMPI INNER (sold as INNER for $12) or Rein boot (sold as a pair for $22). But given how much work is involved, I'd vote for Volvo OEM boot: the price difference is not that much.
A NOTE on Trans seal:
- Note that it is about flushed or at most 0.5mm from surface. Don't drive new seal in too far, you may end up with a leak.
- The seal has 2 lips: the inner lip is the actual seal (it is tightly sealed due to the garter spring), the outer lip is basically there to prevent dirt from coming in.
- I used the pry bar to remove old seal.
- New seal: although you can use a 1.5-inch PVC coupler, I prefer a small piece of wood and install it flushed.
- Seal is by Corteco (Freudenberg-NOK mfg), purchased from rmeuropean dot com for $11. It is an exact fit and finish.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Excellent write-up CN! Great photos, diagrams and labels!
I have new Corteco axle seals for next time I do this, though mine don't leak, are now 19yrs old wtih 215,425mi.
Q on replacing inner boot on pass. side. How to install it when the inner joint won't come apart/slide apart? Trying to slide it over the other end means dealing with the large dia. bearing. My axles are not OEM. Indy bought them from WorldPac long time ago.
M1 10W-30 HM
M1 10W-30 HM
sleddriver,
Re Pass Side axle.
The bearing sits INWARD of the inner CV joint.
So you have no problem working on either Inner or Outer joints.
I am posting a photo from my other DIY so you can see:
Re Pass Side axle.
- sleddriver
Excellent point! I stand corrected...and obviously confused! I'm going to have to redo the outer pass boot due to a rip after only a year or so. I had such difficulty just removing the outer joint (first time, wrong tool), I may have just been finally relieved to get 'er done, that I forgot about doing the inner boot BEFORE the outer!
Thanks for the clarification!
M1 10W-30 HM
M1 10W-30 HM
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Cn90, OD for inner on my cv joint was not 92mm, therefore the Audi boot fit perfectly. You can see the pics in the earlier part of thread, the rein kit has different sized boots.
I've had to replace two inner original GKN boots so they do eventually wear, your job is done but something to think about next time. I would have put on an outer boot on the inner in your case.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
I've also done one or more inner turbo boots, have only used the Audi part, it fits.
A little bit of history on my 98 S70 GLT with 180K:
1- (R) side: dealer installed a NA axle years ago. I know for fact the OUTER joint OD is 82mm b/c I installed the boot recently.
I also installed the INNER using Audi boot (82-mm type), which fit perfectly as described in the 1st page of this thread.
2- (L) side: this is original for sure, b/c the INNER boot said "made in Germany". I know the dealer rebooted the (L) side at 100K or so (I have records).
The OUTER joint OD is definitely 92mm. I remember reading somewhere (maybe I am wrong) that the inner boot for turbo (Volvo OEM PN 31256230) is larger than NA Axle INNER OD, thus this experiment. When I had the INNER joint apart, the diameter was certainly more than 82mm, it was about 92mm or so.
I just checked Volvo OEM PN 31256230, which has the dimension of: L = 85mm, ID = 24mm, OD = 92 mm.
So, northernlights managed to stretch an Audi 82-mm rubber boot over a 92-mm joint, interesting!
PS: As I mentioned above, if I have to do this again, I would buy Volvo Inner boot for $32.
- 2524 Views
Last post by drgswede1978
- 18 Replies
- 1066 Views
- 792 Views
- 11 Replies
- 3204 Views
Last post by theWIFES_S70
- 1339 Views
Last post by 800artfreed
