IMHO, a lot of this is a non-issue. I'm not sure if Asbestos is even used in brake shoes or protective welding sheets anymore. The most likely place a person might still encounter it would be in pipe insulation in old houses ( that white cardboard sort of stuff ), but most systems have been replaced by now. Same applies to siding or flooring.
Like wise with Lead. When it comes to what you or I will come into contact with, It is all mostly " encapsulated " ( OSHA speak for repainted ) by now, so really not the issue it once was. But certification from an abatement company is still sometimes needed to this day. When in question - wet it down if Asbestos, and wear rubber gloves if Lead, is the issue.
What non automotive projects and repairs are you doing?
Forum rules
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Re: What non automotive projects and repairs are you doing?
1999 V70 GLT
1999 V70 GLT
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
What's wrong with using lead? I've seen people use it as filler when doing bodywork rather than Bondo.
I also use lead projectiles that get "expelled" pretty fast at the range.
- Sveedy
Well just make sure you don't ingest that Lead you " expel ". I hear that can lead to death faster than eating paint chips.
When doing body work they should not be touching the Lead or breathing the fumes.
It's really just a matter of common sense, but I shouldn't talk. As a kid I remember holding Mercury that I had found in a thermostat in my bare hands
1999 V70 GLT
1999 V70 GLT
- gnalan
My dad played with mercury out of broken thermometers when he was a kid. And I have no intentions on eating lead of any origin.
Interesting fact, that I just recently found out, is the lead in car batteries are recycled and used in said projectiles.
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
How much lead is it ok to have in your system?
None lead. Zero. No amount of lead.
You still see it in old soldered copper plumbing pipe. We used to breathe it from exhaust pipes.
Lead birdshot kills Eagles and other raptors who ingest it while picking at carcasses, as well as lead bullet fragments from big game.
To think we sanded down to bare wood an entire room of historic moldings in our first house with a baby in a crib. We had him tested after we learned. He was fine.
- gnalan
I don't plan on having lead in my system from anything.
I've used older solder that had lead in it, and didn't think anything of it when the smoky fumes were coming off of it.
Glad your son's ok.
Glad your son's ok.
- gnalan
I saw these in Menard's yesterday while walking around the isles trying to stay out of the heat.
- Been thanked: 1000 times
I have started setting an alarm for 6 AM. High temperatures here are now 100 F and the lows about 78. If I can get started on outside work before 8 AM, it is a little cooler for a couple hours. I still quit by 11 most days.
- Has thanked: 1500 times
- Been thanked: 3812 times
I don’t know how you guys can take that heat. I would be elements C HN O with traces of others if I tried to do anything in that heat
General hot weather advice:
Avoid the hottest part of the day - generally 11 to 5.
Wear light colored clothing.
Drink water early and often.
Avoid alcohol.
Avoid direct sunshine.
Take frequent breaks, in A/C if possible.
Avoid alcohol.
