Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
RickHaleParker wrote: 19 Mar 2023, 15:00
vtl wrote: 19 Mar 2023, 13:38 You don't need level shifters to build a cracker.
I have done the CAN level at 5V ... no damage.
If you want to level shift. Use a CAN Transceiver with level shift built in.
Volvo CAN is 3.3v.
myname
Year and Model: 2007 XC70
Has thanked: 1 time
Been thanked: 4 times
Post by myname »
I still cant get Cemcracker to do much of anything. I took a full video here, showing the crash. I assume at this point my knockoff Dice just isnt up to the task. Please let me know what you think.
Thanks
My car: 2007 XC70 YV4SZ592771280324
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
The "not so good" copied dice versions, seem to have probs with the send periodic msg function which is used for prog mode. I try to do a workaround later...
Silencer711
Year and Model: 2007 S60 2.5T AWD
Has thanked: 1 time
Post by Silencer711 »
T5Luke wrote: 16 Jul 2022, 16:18 If you have a matching car and Dice-206751?
PM me to get software for a try and report back to the forum...
PM'ed you :)
2007 S60 - P2 - B5254T2 - 2.5T - AW50 AWD
- PAST -
2002 S40 - NEDCAR - B4204T3 - Base 1.9T - AW50 FWD | (Given Away)
2001 S80 - P2 - B6284T - T6 - GM 4T65 AWD | (Crashed)
Jackw16
Year and Model: 2014 V40 D3
Has thanked: 1 time
Post by Jackw16 »
Hi guys,
just kind of checking in, i plan on reading up on this post to see if theres any updates to make to the wiki and i finally have a good few days time to really improve the wiki more, i do have one question though, on p3 i took my cem out as i was having a hard time getting it to stay in programming mode and therefore slowing down the cracking as it would constantly re-enter programming mode, im now lending this device to a friend but before i post it to him i wanted to see if anybody has had any luck figuring this out, its a V40 that im finding it hard to keep in programming mode, many thanks, Jack
included a picture of my device setup incase its the length ive extended the can bus by etc, i currently think it could just be the length of these wires but any help is greatly appreciated :)
P.S the Esp01 is just being used to connect to wifi and then share what the teensy is outputting on serial over wifi to a webpage for remote monitoring, or via a phone locally.
vtl
Post by vtl »
V40 is P1, no?
Adding a pause between CAN requests usually helps to early P3 CEMs to stay asleep, however I found it was still quicker to go as fast as it can and re-enter programming mode when needed.
How often is it dropping off the programming mode?
Dudde
Year and Model: 2005 V70 and more
Has thanked: 17 times
Been thanked: 17 times
Post by Dudde »
What is the 3 byte pincode that is used with DHA? Is it different from the 6byte pin or is it possible to convert it to 3 byte pin? Or am i missing something here? 🤔
duzi
Year and Model: S60
Has thanked: 18 times
Been thanked: 5 times
Post by duzi »
3-byte pin is used to adapt the ignition key
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
Can you elaborate what you mean by "adapt"?
duzi
Year and Model: S60
Post by duzi »
Key Programming...
