- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Today I drove my P2 across a mostly empty parking lot and spotted a nice (Betty) black V60 wagon. I’m guessing 2015-17. They look really good. T5 AWD. Not too big, not too small. We’ve wondered sometimes if we could get by with a Golf GTI 4 door, but a V60 would be much much better.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
I considered threading #6-32 3/4" through the tap&die and then cutoff excess with Dremel; but a return and replace with store credit felt simpler.MoVolvos wrote: 19 Nov 2023, 19:07
The 1/2" is cleaner looking also though no one will ever see it :lol:. I noticed I did cut one due to the distance of the double wall. Will see if I can go back and make a change to my post to reflect this. Thanks.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I have a pair of burglar (elbow) length bolt cuttersxHeart wrote: 21 Nov 2023, 09:10I considered threading #6-32 3/4" through the tap&die and then cutoff excess with Dremel; but a return and replace with store credit felt simpler.MoVolvos wrote: 19 Nov 2023, 19:07
The 1/2" is cleaner looking also though no one will ever see it. I noticed I did cut one due to the distance of the double wall. Will see if I can go back and make a change to my post to reflect this. Thanks.
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
A colleage of mine has a V 60R and loves it, nice car in orange. We bought an XC 60 for my wife last year with the 3.0 turbo. Great car, same mileage as my ‘03 XC 70 but more power, nothing bad to say about them at all other than it’s a little high to get the dogs into. I still prefer my old XC overall but we needed to have 1 “newer” car between us. I do like the looks of the P3 XC 70’s though and could see myself in one of those one day .BlackBart wrote: 20 Nov 2023, 19:54 Today I drove my P2 across a mostly empty parking lot and spotted a nice (Betty) black V60 wagon. I’m guessing 2015-17. They look really good. T5 AWD. Not too big, not too small. We’ve wondered sometimes if we could get by with a Golf GTI 4 door, but a V60 would be much much better.
2003 XC 70 (sold)
- Has thanked: 1611 times
- Been thanked: 4072 times
Mrs Dr Abscate insists on one newer car, a 2006 E83 Bavarian Money Waster.
It has been a good ride.
Came home to find she has ordered an Electric Vespa ...I’ve told her NYS requires a leather outfit.
She’s an oldest child, Catholic school educated so she checked the regulations , then ordered her leather kit.
Today I’ll take down the redirect from nysdmv.gov from my router
- Has thanked: 987 times
- Been thanked: 1078 times
Did you misdirect Mrs. A? You dog. Hope she looks good in leather.
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
Not a good news day today...
When I changed the torque rod a couple of weeks ago I noticed undertray was covered in oil. Looking around I saw the bottom of the turbo was covered in oil, I wiped it dry and took the car for a drive, sure enough there was more oil leaking when I returned. The turbo drain on these cars are prone to leaking at the seal but mine was dry, the oil inlet feed banjo bolt was also dry so that is as much as I know about turbos and decided to book the car into a turbo specialist for further inspection.
I dropped the car into the specialist this morning and just had a call to tell me the thrust collar bearing on the cold side is leaking and needs rebuilt. I as told I could have left it for a while without doing any harm but the leak would just get worse. He was surprised that this was the cause as he thought it might have been an intercooler problem. The car won't be ready until the end of the week.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Today I made an appointment with the indie to have the new Ansa exhaust from RockAuto installed on the V70. PO had issues with exhaust leaks and replaced the resonator with a straight pipe. I wasn't a fan of that because the car is a bit louder than it should be. Can't wait to get it done now.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Switched over to winter washer fluid today. Old summer stuff turned to slush and had to run the pump for a bit to get the new fluid through.
Had a long crank this morning, i dont think i let the fuel pump prime and the check valve may be a little leaky. Will monitor next cold start to see.
2008 S60 2.5T Auto (Sold)
