'98 V70 AWD manual swap donor compatibility
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
the subframe on the coupe is really nice and fits on other p80ies.
M58 transmissions are not too hard to find in Europe, but shipping to the states is a hassle noone wants to do. It's a question how much it's worth to you, though.
1996 855 R,
2010 V70 D5,
Culito
Year and Model: 1998 V70
Been thanked: 7 times
Post by Culito »
foggydogg wrote: 23 Apr 2024, 22:09
Culito wrote: 20 Apr 2024, 17:18
I'm going through manual swap threads - I guess I'm taking out the AWD and going FWD. If that's the trade-off, I'll take the third pedal.
Not sure who in my area can help with the ECU flash part. That might be a challenge.
My car thread is here:
viewtopic.php?t=102681
Robert did the same awd/fwd conversion on his son in laws car not long ago, can't remember if it was manual swapped too. Fuel tank and all the fuel lines ended up being a stumble, mostly because he didn't get it all on the first trip to the salvage yard. I think he used stuff off a convertible, and the rear track was wider - which he already knew since he has the same rear setup on his 850T5R.
I figured I'd just remove the rear driveshaft, coupler, etc and call it good. πŸ€·β€β™‚οΈ
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Culito wrote: 24 Apr 2024, 09:19
I have a small selection of driveshafts in the corner of the garage myself.
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
I guess that works, but it's far from ideal. The delta link is a much better and simpler suspension setup that you can actually get parts for. The full rear end can be swapped from the C70, but the tank and lines are different so you'd need the setup from a FWD '98 if going that direction.
Also make sure to save the AWD parts you removed - they're worth some money and very difficult to find, so you can get some of your money back on the swap by selling that stuff.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
Culito
Post by Culito »
I've been pondering this in prep for the manual swap.
Regarding the ECU, is that something I can pull from the 2000 C70 and have it re-flashed for the 98 V70? Just so there's minimal down time.
Who reliably does ECU reprogramming these days?
Thanks.
Has thanked: 1610 times
Been thanked: 4069 times
I think the ECU between 98 and 99 completely changed. Get a used 98 ECU for the flash
foggydogg
Post by foggydogg »
Culito wrote: 22 Jul 2024, 10:52 I've been pondering this in prep for the manual swap.
Thanks.
A suggestion would be to call Robert, I'm sure he would be glad to talk with you about it. His cell in listed on his website.
Culito
Post by Culito »
Random question here, since I'm still mentally preparing for the swap, maybe this summer.
I hear that I can swap in the rear delta link suspension from the C70 when converting to FWD (my AWD system doesn't work anyway).. My question is, can I swap the gas tank over from the coupe as well?
What is compatible?
The c70 rear axle is a wider track than the v70 so you need to roll the fenders to make it fit.
Culito
Post by Culito »
Any ideas about the gas tank?
