That dirty fluid is usually a sign of bad torque converter clutch. Just burnt ATF is brown, not black. If you put one drop of your old fluid on a white paper towel, you'll see worn friction particles.
Also need to check ATF level with the engine running, or the level will be high.
Long term results for 2001 V70 auto transmission drain and fill
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
I still say it's partly because of old fluid(previous owners) + slipping lockup function leading to this disaster. All transmission posts + 2 of my own I've seen have had the same color(brown or worse).vtl wrote: 01 Jun 2025, 20:19 That dirty fluid is usually a sign of bad torque converter clutch. Just burnt ATF is brown, not black. If you put one drop of your old fluid on a white paper towel, you'll see worn friction particles.
- 2861 Views
Last post by Archer
- 3869 Views
Last post by Blacklab467
- 2062 Views
Last post by polskamafia mjl
- 3928 Views
Last post by Integrexman
- 592 Views
Last post by Lordflash
