Assuming you mean for 2-bolt control arms:LamboSE5 wrote:Sorry for the quick question but I need this done now
what are the torque values for the control arm bolts please? and where can I find torque values?
control arm to subframe bolts: 51 ft-lbs then tighten an additional 120 degrees
ball joint pinch bolt: 37 ft-lbs
Best source for torque specs is the Haynes manual. If you spend much time at all wrenching on these cars I'd recommend getting one. It is excellent for almost all repair jobs, really.
