VIDA 2012B VMWare Player Image
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
As of 3/29/13 the files are still available. I installed this on a brand new Windows 8 computer with 8 gig of memory, configured the VM to run at 4 gig and it is amazingly useful. I had an old Vadis disc that I never could get to run clean but this VM setup is really quite good. There's a way to get rid of the Genuine Advantage message if you want to keep the XP up to date. My strongest thanks to the member who made this available to the masses. I keep it up and running all the time and install AVG and a firewall just in case.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
precopster
- Year and Model: Lots
- Been thanked: 128 times
Mine's running well also. I have less at RAM 512mb but it still works great. I also installed AVG and turned off Genuine Advantage notification in Windows updates.
I'm looking for a set of Mac OS10.5 files as I want to have a play with that too.
Thanks again to the OP
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
With some tweaking the vm image will probably work with virtual box: https://www.virtualbox.org/wiki/Downloads
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
I successfully downloaded and installed (4/03/2013) on an old Pentium 4 3.06ghz desktop with 1 gig of ram. It worked well for the little while I played with it, It ran a little slow.
I installed with VMware 3.0 because my pc wouldn't install ver 4 or 5. The VMware has the ram slider greyed out also.
If I wanted to put this on a laptop and actually connect it to my car, would I need a usb OBDII wire?
Thanks.
Thanks.
2004 V70 2.5t 111,xxx miles
1990 240DL stuck at 158,xxx miles
precopster
You need a Dice OBD II readermandomex1 wrote: If I wanted to put this on a laptop and actually connect it to my car, would I need a usb OBDII wire?
Thanks.
boosted5cyl
Its going to be slow with 1GB of RAM for sure. Your own OS needs 512MB at least, VMWare player easily 70MB and then another 512MB for the "guest".mandomex1 wrote:I successfully downloaded and installed (4/03/2013) on an old Pentium 4 3.06ghz desktop with 1 gig of ram. It worked well for the little while I played with it, It ran a little slow.
Thanks.
The VMware machine needs to be completely shutdown (not paused) in order to change the RAM allocated to it. That said with 1GB it might not let you...
You need a DICE or similar adapter to run diags. A "generic" OBD II interface wont work with VIDA, but you will be able to pull most common codes using common software. You can get knock-off DICE adapters off ebay for around $200 I think. I have yet to try one myself.
precopster
Mine still works and is bug free. I saved the image complete to a portable drive so I can share it or reload it.
Oly_850
- Year and Model: 2000 S80 T6
Sorry for the double post....grr.
'12 Ford Focus SE - Black Pearl
Owned:
'00 Volvo S80 T6 - Maroon
'98 Volvo V70 - Red
'90 Volvo 740 GLE - (sold, too far gone)
'96 Volvo 850 GLT - (totaled) :\
Want - A6 Quattro, XC90, C303
Owned:
'98 Volvo V70 - Red
Oly_850
Sorry for the double post, not enough coffee in Seattle this morning. :/
Owned:
'98 Volvo V70 - Red
Owned:
'98 Volvo V70 - Red
Oly_850
Thanks so much for going to all of this work!
I am able to concatenate the files using Keka or Stuffit Expander into one 6.4GB .z7 file. That bit works fine. But when I try to expand the concatenated file, it fails using 3 different expanding tools. Corrupt file? Redownload them all?
My dream:
To run this image in VMWare Fusion or Parallels on my MacBook just for grins.
Thoughts?
My dream:
Thoughts?
Owned:
'98 Volvo V70 - Red
Owned:
'98 Volvo V70 - Red
- 1187 Views
Last post by mrscullini
- 2869 Views
Last post by Sardine
- 1114 Views
Last post by suds
- 1612 Views
Last post by RickHaleParker
- 1659 Views
Last post by XC70Rider
