2001 V70XC - front drive axle broke off at T
Has thanked: 1611 times
Been thanked: 4072 times
xHeart wrote:
chrism wrote:Good job!
Is it just coincidence that the extracted axle is laying on a newspaper ad for new cars? Hmmmmm. :wink:
A reminder to us DIYers that there is always a choice.
Thank you ALL!
Added 2qts MOBIL 3309, and now keeping an eye on few drips on garage floor which is NOT consistent, not like each morning.
Here is a photo, red arrows point to older collections, mostly evaporated. New drive axle seal on at driver's side, or overfill?
Great that it worked out! I was thinking
(III) don't lock the cat in the garage overnight
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
xHeart wrote: 02 Apr 2014, 15:04 Using chisel can be serious. Where to go from here?
Here are two photos. Feeling real bad!
After this broken drive axle incident, I acquired a used pair from a 2007 XC70 with 53,000 miles. Serviced and installed the donor pair, more here: viewtopic.php?f=9&t=62033&start=20
Now looking for a donor drive axle OR just the inner CV joint to replace what broke. I'll then have the original pair of axle on the shelf with new GKN boots ready to use.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Check my classifieds, might have what you need. Need your part #.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
xHeart
Post by xHeart »
E Showell wrote: 14 Apr 2020, 15:42 Check my classifieds, might have what you need. Need your part #.
Volvo CV Left 8252038 -- used in following:
Volvo S60 2.4l 5 cylinder Turbo: 2002
Volvo S60 2.5l 5 cylinder Turbo: 2003, 2004, 2005, 2006, 2007, 2008, 2009
Volvo S80: 2003, 2004, 2005, 2006
Volvo V70 2.4l 5 cylinder Turbo: 2001, 2002
Volvo V70 2.5l 5 cylinder Turbo: 2003, 2004, 2005, 2006, 2007
Volvo V70 XC 2.4l 5 cylinder Turbo: 2001, 2002
Volvo V70 XC 2.5l 5 cylinder Turbo: 2003, 2004, 2005, 2006, 2007
Here is a cleaner pix of original 2001 V70XC drive axle inner cv:
Stumbled onto this old thread.
How in Hades did 7.5 cm of steel axle snap like that?
xHeart
Post by xHeart »
abscate wrote: 16 Apr 2020, 11:37 Stumbled onto this old thread.
I looked at the snapped surface then, a hairline tear with rust was present. Now we know that steel axle can snap.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
If a small crack appeared at some point, it will develop under force. In theory the axle is stressed under torsion, and should be fairly solid - especially that one was genuine. But I've seen another one snapped like this. I remember forcing at the junk yard the same with a 2 ft thick pray bar - no luck, it would simply not budge. Guess slide hammer and weld will fix many of these but there's a chance if the locking ring was stretched (is one removes it and puts it back it will stay wider) or was the wrong size, then not much will remove that axle from the transmission. While there, just for fun, these stuck axles may not be the worst out there
