96 850 Non Turbo. PCV System and Emissions
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
I found success by spraying a little silicone lube on the outside of the small line and inside of the elbow and then mashing them together. Then pushing the elbow on to the manifold nipple. It is a PITA.
Klaus
tourspin69
- Year and Model: 96 850
So might my oil trap be clogged? That why the hose blew off?
Could be, but the rubber glove test will tell you that. Snap a vinyl glove over the (opened) oil filler cap while idling the motor and see if it inflates. If it doesn't - gently rev while watching it.
tourspin69
Will do. Also... Wha type of motor oil do you reccomend? I am diligent with oil changes .
Oils and change intervals are worse than sex, religion, and politics combined..the threads, I mean.
I run synthetic in all my cars now - I converted all of them from regular oil by...changing it....despite the doom and gloom that this would destroy my engines or make them leak..on the internet.
Roughly 7500 mile intervals for changes of oil and filter, Castrol or Mobil 1
Castrol is the oil, Castro is the dictator
Mobil is the oil, Mobile is in Alabama
tourspin69
I have been using full synthetic in all of our cars. Also will use Volvo filter in this 850. Going to try glove test tonight. Will post the result. Assuming that oil trap is impossible to get to even if I wanted to change it.
Klausc
I am about to do my 1996 850. It is a 5 hour job to replace the oil separator, but I am going to do it in 2 days. Day one is to remove everything, clean the throttle and manifold, then take a ride over to the dealer to get the correct parts, including manifold gasket. Day 2 to put it all back together.
It is not a hard job, except for the constant bending over.
I am going with OEM parts because the FCP and IPD 'kits' contain too much stuff that I will not be using and the oil separator is less than $40. Total cost should be around $100.
Klaus
tourspin69
So my car passed the glove test. Actually looked like there was some suction. Not much though. Definitely no air filling in. I did rev the engine as well. Good News
- 23 Replies
- 4724 Views
- 20 Replies
- 4850 Views
Last post by erikv11
- 51 Replies
- 9003 Views
- 1569 Views
Last post by hanzbe420
- 847 Views
Last post by SonicAdventure
