1998 volvov70 p0455 code
tom4342
Year and Model: 1998 v70 awd
Post by tom4342 »
One of the first things i replaced
Tom Hood
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Maybe time to put together your own smoker device, find the leak. There are probably worn out hoses on top of the tank anyway but it is just a hassle of a job to do if you aren't sure it needs to be done.
1998v70xcbill
Year and Model: 1998v70xc
Been thanked: 3 times
Post by 1998v70xcbill »
i am not sure of p0445, but my code of p0440, evap large leak. Find cansiter, pull vacuum on the three lines. If you can't pull vacuum that is your problem.
I had purge valve leaking, and gas tank. I decided to put low air pressure on tank line to find leak. I found leak (easier to hear air leaking than sucking. Good luck.. (don't bow off lines you can't get too)
Bill
tom4342
Post by tom4342 »
Still, havnt found it I think I have replaced every damn hose I can find.
Tom Hood
tom4342
Post by tom4342 »
I've scanned with two different code scanners and found no faults yet my check engine light stays on my Kiwi Bluetooth usually picks up anything.
Tom Hood
Racerxc70
Year and Model: C70 1998 coupe
Post by Racerxc70 »
My 98 C70 coupe had this problem for 11 years each smog inspection I would clear the code by disconnecting the neg cable on the battery
This year I replaced the gas filler neck ($45 used) because I noticed that when I removed my gas cap there was gas on the rubber seal which means thats where the leak is, after replacing the fuel filler pipe I have had no more p0455 codes
Has thanked: 1609 times
Been thanked: 4065 times
Tom..for a small leak you usually have to smoke test to find it if it isn't in the J hose.
In this context the " large leak" reported by the ECU refers to the leak rate, so a small split in the wrong place can give a large leak report
