No OBD. You need to search on Google for a wiring diagram for 1986 Volvo 240.
Hint: http://www.volvowiringdiagrams.com
1986 240dl Stalling
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Advice - Replace FPR.Edger wrote:A. I ran out of gas...Installed new fuel pump...it will bog down
B. Both pumps are working and are strong
C. I have tested the fuel regulator and it is good. Rail is getting up to specs.
D. Lummert asks - Were you able to use a fuel pressure test kit to check fuel pressure?
E. I will test the clamp in the morning
F. Clamped down the hose to restrict the flow of fuel going back to the fuel tank. Revs up beautifully and has no trouble accelerating. So its the FPR
G. Removed Clamp - OK but if I rev it up it will flutter, bog down and want to die.
H. So I guess I am looking for advice on my delima still.
- 7719 Views
Last post by enriquepr21
- 1350 Views
Last post by Adam_Leyva
- 1898 Views
Last post by diggler30
- 1738 Views
Last post by mhgreen
- 18 Replies
- 4431 Views
Last post by rgk
