Buy a short piece of large diameter (same as rad hose) vinyl hose from a plumbing supply or home depot ( these are fully transparent or mostly transparent.) Use it in place of the upper hose ( from thermostat to rad). You can see the coolant flow ( leave the pressure cap off the system ) and by doing so watch the temp at which thermostat begins to open. Flow means the pump is working . Flow will increase once thermostat has opened.
Having see though radiator hoses was a "cool" thing not too long ago. You may even find a cheap one online. I think they suaged in an acrylic section .
Not suggesting you buy one of these but it displays the general idea.
1998 Volvo S70 How to check water pump without pulling?
precopster
- Year and Model: Lots
- Been thanked: 128 times
Hey that would be so cool with Volvo OEM blue coolant, blue is my favourite colour
Also you could easily see if trans fluid is in coolant.
One of these would be nice: http://pages.ebay.com/link/?nav=item.vi ... 45&alt=web
roscoerich
- Year and Model: S70 1998
That does look cool, thanks again everyone. If I don't have to mess with the water pump right now, that's more than fine with me. Will keep an eye on any leaks from the water pump. Is it a bad idea to continue running the engine without the thermostat, being in the Texas heat the consensus I get is it's not really necessary, but wanted to get everyone's opinion, also could it possibly affect passing emissions test since the engine is running a little cooler. I've had issues the last three years getting it passed ( any tips?)
RoscoRich
1998 Volvo S70
1970 MGB Roadster Right Side Drive
2006 Hyundai Tuscon
1998 Volvo S70
2006 Hyundai Tuscon
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I would not run a car without thermostat.
My advice is don't drive it without it.
Put in 87 or 90 degree thermostat.Let it be Vernet or Wahler(quality ones) and bleed the system properly.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
