1998 V70 Spark plugs look dirty, but are they normal?
This topic is in the MVS Volvo Repair Database » Spark Plug Wars - What's Best for Your Volvo
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I wrote a DIY for my 2005 XC90 2.5T engine with 90K, see the link below for photos...
https://www.matthewsvolvosite.com/forums ... 10&t=64080
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
'00 S70, '04 S60 and the never ending quest for Stage Zero
dosbricks
Been thanked: 4 times
Post by dosbricks »
Russ, that is the best yet!
Steve, re-tap the holes! They will work for 100K!
cn90, Volvo makes turbo and NA engines. NA has much higher compression ratio. They use different plugs. This thread is about plugs for a Volvo NA engine. Actually it's about what is causing the black deposits on the OP's plugs, but that is of course irrelevant at this point. :D
Erik, where are you when we need you!
Matt, this is the best dang thread on this forum in months. I just showed the latest to my wife and she is :lol: :lol: :lol: all the way back into the kitchen.
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
just, well, currently unable to post ...
durk80
Year and Model: 240 DL 1990
Post by durk80 »
I too drive short trips to work and back (roughly 3 miles each way), and my 240 dl's NGK plugs look like that as well--carbon black soot, not greasy. On some advice, I replaced the thermostat and cleaned the new plugs that I put in about 3 weeks ago, and it still doesn't seem like the car is running at 100%.
This is a post that I started, but I haven't found the answer yet:https://www.matthewsvolvosite.com/forums/viewtopic.php?f=2&t=72628
Since your car has OBD II, you can always get the codes read at an Auto Zone for free. That might give you a better clue to what's happening inside your engine.
Post by cn90 »
dosbricks wrote:...cn90, Volvo makes turbo and NA engines. NA has much higher compression ratio. They use different plugs. This thread is about plugs for a Volvo NA engine. Actually it's about what is causing the black deposits on the OP's plugs, but that is of course irrelevant at this point. :D
dosbricks,
I hope you know that Volvo PN 8642660 (spark plugs) is used for virtually all engines with 5 cylinders ranging from 850, S70, S60 etc., turbo and no-turbo models. The Volvo OEM plug is basically re-branded Bosch copper and that is it. It is $2/each if Bosch copper, but $5/each when the Volvo logo is imprinted on the Bosch plug.
The black deposit in the original thread was already addressed, likely leaking fuel injector or valve stem seals.
dosbricks
Post by dosbricks »
cn90, here is link to 8642660:
https://www.fcpeuro.com/products/volvo- ... 60-8642660
It's a three prong plug. Notice that every vehicle listed on the fitment guide is an NA? Are the Volvos you own NA? Have you used this plug in your turbos? Does Bosch offer this three prong plug developed by Volvo for 2.4 NA engines for $2 each? Note that in 1997 the 850 GLT became a turbo--do you see that vehicle on the list?--no.
Fits These Cars
Volvo 850
1994 Volvo 850 Base Spark Plug Kit
1994 Volvo 850 GLT Spark Plug Kit
1995 Volvo 850 Base Spark Plug Kit
1995 Volvo 850 GLT Spark Plug Kit
1996 Volvo 850 Base Spark Plug Kit
1996 Volvo 850 GLT Spark Plug Kit
1997 Volvo 850 Base Spark Plug Kit
1993 Volvo 850 GLT Spark Plug Kit
Volvo S60
2001 Volvo S60 Base 2.4L L5 Spark Plug Kit
Aspiration: Naturally Aspirated
2002 Volvo S60 Base 2.4L L5 Spark Plug Kit
2003 Volvo S60 Base 2.4L L5 Spark Plug Kit
2004 Volvo S60 2.4 2.4L L5 Spark Plug Kit
2005 Volvo S60 2.4 2.4L L5 Spark Plug Kit
Volvo S70
1999 Volvo S70 Base 2.4L L5 Spark Plug Kit
2000 Volvo S70 Base 2.4L L5 Spark Plug Kit
1998 Volvo S70 Base Spark Plug Kit
Volvo V70
2001 Volvo V70 Base 2.4L L5 Spark Plug Kit
2003 Volvo V70 Base 2.4L L5 Spark Plug Kit
1998 Volvo V70 Base Spark Plug Kit
1999 Volvo V70 Base 2.4L L5 Spark Plug Kit
2002 Volvo V70 Base 2.4L L5 Spark Plug Kit
2000 Volvo V70 Base 2.4L L5 Spark Plug Kit
2004 Volvo V70 2.4 2.4L L5 Spark Plug Kit
2005 Volvo V70 2.4 2.4L L5 Spark Plug Kit
2006 Volvo V70 2.4 2.4L L5 Spark Plug Kit
2007 Volvo V70 2.4 2.4L L5 Spark Plug Kit
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
cn90 wrote:...dosbricks,
Nope :!:
On oem Volvo spark plugs for non-turbo engines(set of 5) is stamped EXL turbo. :wink:
Oem Volvo spark plugs(set of 5) are different for turbo & non turbo models. :!:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
These ones are for turbos:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
dosbricks
Post by dosbricks »
Thanks misha. And thanks Erik! There is no way I could say it any better than that. :mrgreen:
