2001 V70 Crank no Start
01_Nautic_V70
Year and Model: 2008 XC90 V8
Been thanked: 8 times
Post by 01_Nautic_V70 »
Disconnect the MAF. Does the engine run in limp home mode?
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
01_Nautic_V70 wrote: 08 Dec 2019, 21:37 Disconnect the MAF. Does the engine run in limp home mode?
Just disconnected the battery and pulled down the CEM to check the fuel pump relay, so, I can't do that test now.
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
01_Nautic_V70
For me, this was the clue. I knew I was getting spark, knew it was getting fuel, so it had to be air. That things changed when MAF was disconnected was the pointer on where to look.
DanelleNavarro
Year and Model: 2002 v70xc
Post by DanelleNavarro »
I'm having crank no start issues also however if it is the fuel pump why does my car start with a jump. I tried listening for the fuel pump noise and I didn't hear anything my friend also get tried to hear the fuel pump noise and didn't hear anything another friend same thing nothing we put the battery jumper cables to it and it started right up we don't understand how that is possible if the fuel pump is broken
01_Nautic_V70
Sounds like you are getting fuel, are you getting spark? Air?
DanelleNavarro
Not sure about the spark will check in the morning and what do you mean by air?
01_Nautic_V70
Air is regulated by the electronic throttle module based on what the ECM tells it to do. The ECM looks at the mass air flow sensor to figure out how much air is going in. If you unplug the MAF (located just downstream of the air filter box) the car should go into a limp home mode where it uses its best guess for how much air is going in instead of the measured amount. If so, the car would start though it may idle rough.
DanelleNavarro
Ok...I'll give that a try I also have changed my coil harness wires, the oil filter, and change the oil. I unplugged the relay for the fuel pump and swapped it out for the fog light relay but that didn't do anything the car will still start on a jump though. That's where my confusion begins. Because if it's the fuel pump would it still start on a jump? Also there is good fuel pressure on the fuel rail. However I have a problem with my number 2 cylinder misfiring constantly. Would that have anything to do with my problem starting the car?
Has thanked: 1611 times
Been thanked: 4071 times
What’s the measured fuel pressure at the rail? You can’t do this visually
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
DanelleNavarro wrote: 16 Aug 2020, 19:24 we put the battery jumper cables to it and it started right up
Sounds to me like a case of not enough battery power, after cranking the starter, to adequately power the fuel and/or ignition system(s).
If you haven’t done it already, try cleaning the battery terminals. After you do that and reconnect the cables put a volt meter across the battery terminals and see how much the voltage drops when cranking the starter. Your problem might be as simple as dirty battery terminals or a weak battery.
