850R AUT hard shifts
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Hmm... power flushing these transmissions isn't recommended at all - it's common for that kind of treatment to dislodge sediments/damage seals. The recommended way to do it is "drain and fill", i.e. a slow drain, then replacing the drained amount. Then again, and again until the fluid's the right color.
There's a definite possibility that you've got internal damage because of the flushing, and the hard shifting and pressure loss supports that, I'm afraid. :(
- S
[Sold] '97 S70 T5
kevinwalter
Year and Model: V70n 2000, 850R 1996
Post by kevinwalter »
Hmm, that's the first time I've heard that.
Just found out the following:
Maybe try Mannol instead of Ardeca? Just to check if it's not the oil.
Sommerfeldt
It's pretty much all over the forum. :) Remember that Volvo didn't intend these transmissions to even have the oil changed at all. :) 0.5 bar is a pretty serious pressure loss - it's worth a shot of course - it probably won't hurt. But, with a pressure loss like that, damage to internals has to be on your radar. I'm surprised that you get no DTCs from the tranny with that kind of deficiency, though...
- S
[Sold] '97 S70 T5
kevinwalter
Alright, have had some days off so I did not work on my car.
Could it be a bad line-pressure solenoid or a a bad wiring-harness to that solenoid?
Is it possible to test that solenoid?
I'm still not convinced that it's my transmission because it's shifting exactly like the one I've had before.
kevinwalter
Just found out a nice document about measuring the resistance of the solenoids. It should be almost the same at the TCM side. If it's not you've got a wiring problem.
I'm going to check this in the weekend. Hope for the best....
http://www.vectra-club.ru/images4faq/ov ... 0-42LE.pdf
kevinwalter
The resistance of Solenoid 2 a bit more then 15 ohms. 15,8 ohms exactly. Could that be a bad solenoid?
simonology101
Year and Model: 850 1995
Post by simonology101 »
When it shifts it vibrates you say..... Motor Mounts my friend and the upper tranny mounts as well. it sounds good though.
2002 S40 Sold
1995 850 NA Daily Driver
kevinwalter
No, it does not vibrate anymore. It just shifts hard.
Found out that a connection on my TCM was a bit smugged. It appeard to be the TPS sensor wire. Cleaned that and it shifted a bit smoother. Still a hard bang in Reverse...
My idle is almost 1000 RPM. +- 980? Is that normal?
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 85 times
Post by hausmeister »
idle should be 850rpm ;)
850 T5-R '95 auto Image
kevinwalter
hausmeister wrote:idle should be 850rpm ;)
So this is a bit to high?
